[Qgis-community-team] update qgis sample dataset
Otto Dassau otto.dassau at gmx.de
Mon Oct 6 05:13:27 EDT 2008
Hi Jürgen,
On Sun, 5 Oct 2008 13:54:07 +0200
Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi,
> On Mon, 15. Sep 2008 at 12:38:04 +0200, Otto Dassau wrote:
> > For the updated dataset I changed almost only data in the GRASS location:
> > - renamed folder grass to grassdata, because that is the usual name used for
> > a GRASS Database folder in all known literature
> > - fixed the gtopo30 elevation map.
> > - fixed the alaska boundary map. There were some topological errors. I
> > updated the fixed alaska map also into the vmap0_shapefiles folder.
> A vector layer that has some attribute data to demonstrate the different
> renderers would be nice too and maybe a sample project that also
> contains a WMS and/or WFS layer with alaskan data - if available.
Some of the vector data include different attribute values e.g.:
lakes: name (varchar), area (real)
airports: name (varchar), use (varchar), elevation (integer), ...
majrivers: name (varchar), length (real)
but we could extend this, of course! What do you have in mind for a nice usage
example?
A sample project is a good idea, too. We still collect data sources (incl.
WMS/WFS) here: http://wiki.qgis.org/qgiswiki/ManualManagement but it would be
nice to have more formats...
regards,
 Otto
> Jürgen
More information about the Qgis-community-team mailing list
