[Qgis-community-team] Re: [Qgis-user] QGIS alaska dataset reprojected to EPSG 2964
Paolo Cavallini cavallini at faunalia.it
Wed Oct 8 08:57:16 EDT 2008
Otto Dassau ha scritto:
> As Gary suspects, the projection engine in QGIS isn't recognizing the to_meter
> parameter correctly. So I reprojected and updated the QGIS sample data set using
> this EPSG 2964 CRS.
Thanks for this.
Will it be possible to fix the problem upstream? Projections are often
sources of problems since quite a bit.
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
More information about the Qgis-community-team mailing list
