[Qgis-community-team] Re: Updates to ManualTasks page
Otto Dassau otto.dassau at gmx.de
Sun Aug 9 14:43:53 EDT 2009
Hi Carson,
On Sun, 09 Aug 2009 19:04:43 +0100
Carson Farmer <carson.farmer at gmail.com> wrote:
> Hi manual team,
> Now that the website is back up again, I have updated the ManualTasks
> Wiki page:
> http://www.qgis.org/wiki/ManualTasks
> Otto, if you have a second, maybe you could confirm that this is
> correct? I used the following command to produce the output (then edited
> it to remove anything that wasn't relevant to the manual):
> svn log -r10531:11242 | grep -i '^[a-z][a-z]' | sed -e "s\^\* \1" >
> /home/cfarmer/qgis_manual/log.txt
> As far as I can tell, the above are the revisions from the end of the
> last release, to the start of the feature freeze.
the list looks very goood and revision 10531 is from 11. Apr 2009 right after
feature freeze for version 1.1- so that should fit.
Regards,
 Otto
> Cheers,
> Carson
More information about the Qgis-community-team mailing list
