[Qgis-community-team] compiling manual & image quality
MORREALE Jean Roc jr.morreale at enoreth.net
Fri Aug 21 08:36:15 EDT 2009
Otto Dassau a écrit :
> On Fri, 21 Aug 2009 13:11:40 +0200
>>> Hi Jean Roc,
>>> On Fri, 21 Aug 2009 11:04:10 +0200
>>>> Hi,
>>>> I've been compiling the french manual for 1.0 (using texlive2008) but
>>>> the quality of the images is very low : the jpg figuring in the final
>>>> pdf are full of compression blocks making some captures hard to read.
>>>> All the source's images have been localized and saved as png (96dpi) so
>>>> I would really like to have them show up in a better quality.
>>>> What are the right options to change ?
>>> All images are simply converted during compilation without any change of
>>> size or
>>> resolution. In the english version, many figures are screenshots with only
>>> 72dpi
>>> resolution. You are right they sometimes could be better, but I don't know
>>> of
>>> any parameter for dvipdf or dvips conversion that make the images look
>>> better,
>>> except using images with a higher resolution - just my 2c.
>>> Regards,
>>>  Otto
>> Hi Otto,
>> It is not a matter of size or resolution but of jpeg artifacts due to a
>> drastic compression, when I compare the png/eps they do not show these
>> blocks but the jpgs included in the pdf are full of it. I think  the
>> quality setting used by convert is below 60%, if we could get it up to
>> 75% the images would be less blocky and still around 5% of the size of
>> the pngs
> Hi Jean Roc,
> ok, but since the pdf figures are created from eps format, I wonder where
> we can improve the process since b) uses eps files created in a):
> a) convert PNG and JPEG to EPS defined in the Makefiles
> b) create a PDF with dvipdf (a combination of dvips and ps2pdf) using EPS
> figures from a)
> and when I look at the branches/1.0.0/french/user_guide folder, I don't
> see any jpeg images except the qgis logo on the front page, or am I wrong?
> Can you give an example image where you think there is a big quality problem?
> Regards,
>  Otto
For example take a look at startup1.0.0.png and the image as it appears
in the pdf (here saved as a jpg but could have been exported as a tiff
with the same defects), you can see color distorsion and noise which are
typical of an heavy quantization step:
http://uppix.net/5/e/6/4197c43cfb28e319c4889368f40cd.png
http://uppix.net/d/a/b/83b44bd238113703618b279045a45.jpg
More information about the Qgis-community-team mailing list
