[Qgis-community-team] Snapping tolerance and search radius
Otto Dassau otto.dassau at gmx.de
Thu Jan 22 02:05:08 EST 2009
Hi Carlos,
thanks for your patch.
I added it to trunk and tags in svn and restructured that part in the manual a
little. I hopefully it is ok now - you also find it in the pdf pp.45
reards,
 Otto
On Wed, 21 Jan 2009 20:31:49 +0100
Carlos Dávila <cdavilam at orangecorreo.es> wrote:
> I think text in Working with vector > Setting the Snapping Tolerance
> doesn't reflect clearly current behavior of snapping tolerance and
> search radius functions in QGIS. Attached is a patch that I hope you
> find adapted to changes in these too distances done some time ago after
> some discussion in dev list.
> Regards
> Carlos
More information about the Qgis-community-team mailing list
