[Qgis-community-team] Release date for manual 1.1
Carson Farmer carson.farmer at gmail.com
Mon May 4 13:07:37 EDT 2009
Otto Dassau wrote:
> Hi Claudia and Carson,
> On Thu, 30 Apr 2009 00:05:16 -0700
> Claudia A Engel <cengel at stanford.edu> wrote:
>> Otto and Carson,
>> I edited the changes for Postgis SLL mode, improved handling of
>> postgis layers and the map units/pixels addition and committed those
>> to svn.
>> These edits are reflected on the Manual Task page. I tested to make
>> sure, and it all seems to compile fine here. I hope this is all ok,
>> but me know if I should do something differently, as I have never done
>> this before.
>> I also added the headers for the following subsections as discussed,
>> but they need to be written:
>> -Spatialite Layers
>> -Diagram overlay tab
> I added the diagram overlay section with an example. I also added a new vector
> shape layer to the qgis sample dataset and updated the files and the readme.txt
> on the server.
> http://download.osgeo.org/qgis/data/
> Maybe you can check if it is ok, especially with the language. It's great to
> have native speakers in the new team :).
>> -Working with the attribute table
>> Lastly, the new Vector Load dialogue needs still to be added in. I can
>> probably do this, plus another of the chapters above, this weekend.
>> So if anyone can help out with the other chapters, that would be great.
>> Thanks, Claudia
>> On Apr 29, 2009, at 2:50 AM, Carson Farmer wrote:
>>> Hi team,
>>>> I saw that Carson already did something here.
>>>> Carson what was your idea when you created the
>>>> "plugins_diagram_overlay_images"
>>>> folder? Do you plan to add an extra subsection for this plugin in
>>>> the plugin
>>>> chapter?
>>> Well for starters I needed an icon for the core plugins chapter ;-)
>>> But yes, I will be adding a section to the plugin as well. It would
>>> be nice to see what Claudia has done as well, so that we don't end
>>> up duplicating each others work... Claudia, have you committed your
>>> edits yet?
>>>> Or should it work as for the SPIT Plugin. It is listed in section
>>>> 12 "Using Core
>>>> Plugins" but there doesn't exist a SPIT plugin subsection. The
>>>> description can
>>>> be found in section 5.2.4 together with the PostGIS stuff.
>>> hmm, now that I think of it, this might be the best route to take...
>>> this adds more work to Claudia's list, so Claudia if you need help
>>> just let us know... I imagine that in the future the vector overlay
>>> stuff will become completely part of core, so putting it in the
>>> working with vector layers section now might save some hassle later
>>> on as well...
>>> In this case, I think I'll add two new subsections for SPIT and the
>>> Overlay stuff in the Using core plugins chapter, pointing the user
>>> to the sections in the working with vector layers Chapter...
>>>> For the diagram_overlay plugin this would mean, we add it to the
>>>> list of core
>>>> plugins but the description would go into working_with_vector.tex
>>>> and we use the
>>>> folder diagram_overlay plugin_images/ for the plugin icons and
>>>> screenies. Is
>>>> that correct?
>>> see above
>>>>> - Changes in attribute table
>>>>> I could not find any description of the attribute table in the
>>>>> manual,  but maybe I looked in the wrong place. If there is none,
>>>>> is it  necessary to have one? Add another subsection?
>>>> yes, I haven't found anything, too. In the other email I suggested
>>>> to add a new
>>>> subsubsection to 5.4 Editing \subsection{Working with the attribute
>>>> table} just
>>>> above the Query Builder?
>>> This would be good. We should at least mention that there is an
>>> attribute table somewhere... also, the attribute table is relatively
>>> fast compared with other GIS, so this should probably be mentioned...
>>>>> - Improved handling of postGIS layers.
>>>>> I did not look around very thoroughly, but at first glance I could
>>>>> not  figure out what this exactly refers to.
>>>> I don't know either? Carson, do you know? Otherwise we can ask
>>>> Jürgen, I guess
>>>> we did those improvements.
>>> Yeh, Jürgen would be the one to ask... the SSL mode change is
>>> probably one of the bigger changes, and increases PostGIS access
>>> speed by up to 5 times in some cases!
> thanks
>  Otto
Hi guys,
Sorry for my silence the last few days, I have been unexpectedly out of
town for the past 4 days :-(
I'm back now, and will have a look at the changes above... I did a bit
of work on the road, so I will try to commit these tonight when I'm
settled back in. I will keep you all updated with that, and hopefully we
can make this deadline!
As Otto mentioned in a previous email, I think it is really important
that we have an IRC meeting when this is finished to debrief, and talk
about what worked/didn't work for people etc. (I'll also make sure I
show up this time!).
Cheers,
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
National University of Ireland, Maynooth,
Email: Carson.Farmer at gmail.com
Web:   http://www.carsonfarmer.com/
       http://www.ftools.ca/
More information about the Qgis-community-team mailing list
