[Qgis-community-team] Release date for manual 1.1
Otto Dassau otto.dassau at gmx.de
Mon May 4 13:33:55 EDT 2009
On Mon, 4 May 2009 10:14:05 -0700
Claudia A Engel <cengel at stanford.edu> wrote:
> I committed the remaining pieces of Chap 5 last night - hope I got it
> all right.
> I won't have time now until later in the week.
thanks Claudia!
I also finished my sections according to the table at:
http://www.qgis.org/wiki/index.php/Manual_Writing#Document_Maintainers
maybe the others Anne, Werner and Stephan can give us a short "report" about the
status and what is left and if you need some help.
I don't know, if Tim will announce the release tomorrow? But anyway we should
try to finish the manual the next days.
regards,
 Otto
> Claudia
> On May 4, 2009, at 10:07 AM, Carson Farmer wrote:
> > Otto Dassau wrote:
> >> Hi Claudia and Carson,
> >> On Thu, 30 Apr 2009 00:05:16 -0700
> >>> Otto and Carson,
> >>> I edited the changes for Postgis SLL mode, improved handling of
> >>> postgis layers and the map units/pixels addition and committed
> >>> those  to svn.
> >>> These edits are reflected on the Manual Task page. I tested to
> >>> make  sure, and it all seems to compile fine here. I hope this is
> >>> all ok,  but me know if I should do something differently, as I
> >>> have never done  this before.
> >>> I also added the headers for the following subsections as
> >>> discussed,  but they need to be written:
> >>> -Spatialite Layers
> >>> -Diagram overlay tab
> >> I added the diagram overlay section with an example. I also added a
> >> new vector
> >> shape layer to the qgis sample dataset and updated the files and
> >> the readme.txt
> >> on the server.
> >> http://download.osgeo.org/qgis/data/
> >> Maybe you can check if it is ok, especially with the language. It's
> >> great to
> >> have native speakers in the new team :).
> >>> -Working with the attribute table
> >>> Lastly, the new Vector Load dialogue needs still to be added in. I
> >>> can  probably do this, plus another of the chapters above, this
> >>> weekend.
> >>> So if anyone can help out with the other chapters, that would be
> >>> great.
> >>> Thanks, Claudia
> >>> On Apr 29, 2009, at 2:50 AM, Carson Farmer wrote:
> >>>> Hi team,
> >>>>> I saw that Carson already did something here.
> >>>>> Carson what was your idea when you created the
> >>>>> "plugins_diagram_overlay_images"
> >>>>> folder? Do you plan to add an extra subsection for this plugin
> >>>>> in  the plugin
> >>>>> chapter?
> >>>> Well for starters I needed an icon for the core plugins chapter ;-)
> >>>> But yes, I will be adding a section to the plugin as well. It
> >>>> would  be nice to see what Claudia has done as well, so that we
> >>>> don't end  up duplicating each others work... Claudia, have you
> >>>> committed your  edits yet?
> >>>>> Or should it work as for the SPIT Plugin. It is listed in
> >>>>> section  12 "Using Core
> >>>>> Plugins" but there doesn't exist a SPIT plugin subsection. The
> >>>>> description can
> >>>>> be found in section 5.2.4 together with the PostGIS stuff.
> >>>> hmm, now that I think of it, this might be the best route to
> >>>> take...  this adds more work to Claudia's list, so Claudia if you
> >>>> need help  just let us know... I imagine that in the future the
> >>>> vector overlay  stuff will become completely part of core, so
> >>>> putting it in the  working with vector layers section now might
> >>>> save some hassle later  on as well...
> >>>> In this case, I think I'll add two new subsections for SPIT and
> >>>> the  Overlay stuff in the Using core plugins chapter, pointing
> >>>> the user  to the sections in the working with vector layers
> >>>> Chapter...
> >>>>> For the diagram_overlay plugin this would mean, we add it to
> >>>>> the  list of core
> >>>>> plugins but the description would go into
> >>>>> working_with_vector.tex  and we use the
> >>>>> folder diagram_overlay plugin_images/ for the plugin icons and
> >>>>> screenies. Is
> >>>>> that correct?
> >>>> see above
> >>>>>> - Changes in attribute table
> >>>>>> I could not find any description of the attribute table in the
> >>>>>> manual,  but maybe I looked in the wrong place. If there is
> >>>>>> none,  is it  necessary to have one? Add another subsection?
> >>>>> yes, I haven't found anything, too. In the other email I
> >>>>> suggested  to add a new
> >>>>> subsubsection to 5.4 Editing \subsection{Working with the
> >>>>> attribute  table} just
> >>>>> above the Query Builder?
> >>>> This would be good. We should at least mention that there is an
> >>>> attribute table somewhere... also, the attribute table is
> >>>> relatively  fast compared with other GIS, so this should probably
> >>>> be mentioned...
> >>>>>> - Improved handling of postGIS layers.
> >>>>>> I did not look around very thoroughly, but at first glance I
> >>>>>> could  not  figure out what this exactly refers to.
> >>>>> I don't know either? Carson, do you know? Otherwise we can ask
> >>>>> Jürgen, I guess
> >>>>> we did those improvements.
> >>>> Yeh, Jürgen would be the one to ask... the SSL mode change is
> >>>> probably one of the bigger changes, and increases PostGIS access
> >>>> speed by up to 5 times in some cases!
> >> thanks  Otto
> > Hi guys,
> > Sorry for my silence the last few days, I have been unexpectedly out
> > of town for the past 4 days :-(
> > I'm back now, and will have a look at the changes above... I did a
> > bit of work on the road, so I will try to commit these tonight when
> > I'm settled back in. I will keep you all updated with that, and
> > hopefully we can make this deadline!
> > As Otto mentioned in a previous email, I think it is really
> > important that we have an IRC meeting when this is finished to
> > debrief, and talk about what worked/didn't work for people etc.
> > (I'll also make sure I show up this time!).
> > Cheers,
> > Carson
> > Carson J. Q. Farmer
> > ISSP Doctoral Fellow
> > National Centre for Geocomputation (NCG),
> > National University of Ireland, Maynooth,
> > Email: Carson.Farmer at gmail.com
> > Web:   http://www.carsonfarmer.com/
> >      http://www.ftools.ca/
More information about the Qgis-community-team mailing list
