[Qgis-community-team] Release date for manual 1.1
Otto Dassau otto.dassau at gmx.de
Mon May 4 14:02:15 EDT 2009
On Mon, 04 May 2009 19:45:49 +0200
Anne Ghisla <a.ghisla at gmail.com> wrote:
> Otto Dassau ha scritto:
> > Hi,
> [cut]
> > maybe the others Anne, Werner and Stephan can give us a short "report" about
> > the
> > status and what is left and if you need some help.
> On my side, I updated the first chapters with new features and some
> links, basing on the list and the commits.
> There are some features that I really don't know, therefore I wrote few
> words about pointing to the relative sections. Hope it is not a nuisance :)
> What about screenshots of QGIS application? When I run self-compiled
> QGIS, the title of the main window is 'QGIS 1.1.0 Pan (Unstable)'. Shall
> I wait for official packages to update those screenies?
no - I built from the tagged tar.gz and also have 1.1.0 Pan (Unstable). That
seems to be ok, I guess, because stable is 1.0.
> > I don't know, if Tim will announce the release tomorrow? But anyway we
> > should try to finish the manual the next days.
> Ok. I'll be available for the meeting and further work on the manual.
> regards,
> Anne
> > regards,
> >  Otto
> >> Claudia
> >> On May 4, 2009, at 10:07 AM, Carson Farmer wrote:
> >>> Otto Dassau wrote:
> >>>> Hi Claudia and Carson,
> >>>> On Thu, 30 Apr 2009 00:05:16 -0700
> >>>> Claudia A Engel <cengel at stanford.edu> wrote:
> >>>>> Otto and Carson,
> >>>>> I edited the changes for Postgis SLL mode, improved handling of
> >>>>> postgis layers and the map units/pixels addition and committed
> >>>>> those  to svn.
> >>>>> These edits are reflected on the Manual Task page. I tested to
> >>>>> make  sure, and it all seems to compile fine here. I hope this is
> >>>>> all ok,  but me know if I should do something differently, as I
> >>>>> have never done  this before.
> >>>>> I also added the headers for the following subsections as
> >>>>> discussed,  but they need to be written:
> >>>>> -Spatialite Layers
> >>>>> -Diagram overlay tab
> >>>> I added the diagram overlay section with an example. I also added a
> >>>> new vector
> >>>> shape layer to the qgis sample dataset and updated the files and
> >>>> the readme.txt
> >>>> on the server.
> >>>> http://download.osgeo.org/qgis/data/
> >>>> Maybe you can check if it is ok, especially with the language. It's
> >>>> great to
> >>>> have native speakers in the new team :).
> >>>>> -Working with the attribute table
> >>>>> Lastly, the new Vector Load dialogue needs still to be added in. I
> >>>>> can  probably do this, plus another of the chapters above, this
> >>>>> weekend.
> >>>>> So if anyone can help out with the other chapters, that would be
> >>>>> great.
> >>>>> Thanks, Claudia
> >>>>> On Apr 29, 2009, at 2:50 AM, Carson Farmer wrote:
> >>>>>> Hi team,
> >>>>>>> I saw that Carson already did something here.
> >>>>>>> Carson what was your idea when you created the
> >>>>>>> "plugins_diagram_overlay_images"
> >>>>>>> folder? Do you plan to add an extra subsection for this plugin
> >>>>>>> in  the plugin
> >>>>>>> chapter?
> >>>>>> Well for starters I needed an icon for the core plugins chapter ;-)
> >>>>>> But yes, I will be adding a section to the plugin as well. It
> >>>>>> would  be nice to see what Claudia has done as well, so that we
> >>>>>> don't end  up duplicating each others work... Claudia, have you
> >>>>>> committed your  edits yet?
> >>>>>>> Or should it work as for the SPIT Plugin. It is listed in
> >>>>>>> section  12 "Using Core
> >>>>>>> Plugins" but there doesn't exist a SPIT plugin subsection. The
> >>>>>>> description can
> >>>>>>> be found in section 5.2.4 together with the PostGIS stuff.
> >>>>>> hmm, now that I think of it, this might be the best route to
> >>>>>> take...  this adds more work to Claudia's list, so Claudia if you
> >>>>>> need help  just let us know... I imagine that in the future the
> >>>>>> vector overlay  stuff will become completely part of core, so
> >>>>>> putting it in the  working with vector layers section now might
> >>>>>> save some hassle later  on as well...
> >>>>>> In this case, I think I'll add two new subsections for SPIT and
> >>>>>> the  Overlay stuff in the Using core plugins chapter, pointing
> >>>>>> the user  to the sections in the working with vector layers
> >>>>>> Chapter...
> >>>>>>> For the diagram_overlay plugin this would mean, we add it to
> >>>>>>> the  list of core
> >>>>>>> plugins but the description would go into
> >>>>>>> working_with_vector.tex  and we use the
> >>>>>>> folder diagram_overlay plugin_images/ for the plugin icons and
> >>>>>>> screenies. Is
> >>>>>>> that correct?
> >>>>>> see above
> >>>>>>>> - Changes in attribute table
> >>>>>>>> I could not find any description of the attribute table in the
> >>>>>>>> manual,  but maybe I looked in the wrong place. If there is
> >>>>>>>> none,  is it  necessary to have one? Add another subsection?
> >>>>>>> yes, I haven't found anything, too. In the other email I
> >>>>>>> suggested  to add a new
> >>>>>>> subsubsection to 5.4 Editing \subsection{Working with the
> >>>>>>> attribute  table} just
> >>>>>>> above the Query Builder?
> >>>>>> This would be good. We should at least mention that there is an
> >>>>>> attribute table somewhere... also, the attribute table is
> >>>>>> relatively  fast compared with other GIS, so this should probably
> >>>>>> be mentioned...
> >>>>>>>> - Improved handling of postGIS layers.
> >>>>>>>> I did not look around very thoroughly, but at first glance I
> >>>>>>>> could  not  figure out what this exactly refers to.
> >>>>>>> I don't know either? Carson, do you know? Otherwise we can ask
> >>>>>>> Jürgen, I guess
> >>>>>>> we did those improvements.
> >>>>>> Yeh, Jürgen would be the one to ask... the SSL mode change is
> >>>>>> probably one of the bigger changes, and increases PostGIS access
> >>>>>> speed by up to 5 times in some cases!
> >>>> thanks  Otto
> >>> Hi guys,
> >>> Sorry for my silence the last few days, I have been unexpectedly out
> >>> of town for the past 4 days :-(
> >>> I'm back now, and will have a look at the changes above... I did a
> >>> bit of work on the road, so I will try to commit these tonight when
> >>> I'm settled back in. I will keep you all updated with that, and
> >>> hopefully we can make this deadline!
> >>> As Otto mentioned in a previous email, I think it is really
> >>> important that we have an IRC meeting when this is finished to
> >>> debrief, and talk about what worked/didn't work for people etc.
> >>> (I'll also make sure I show up this time!).
> >>> Cheers,
> >>> Carson
> >>> Carson J. Q. Farmer
> >>> ISSP Doctoral Fellow
> >>> National Centre for Geocomputation (NCG),
> >>> National University of Ireland, Maynooth,
> >>> Email: Carson.Farmer at gmail.com
> >>> Web:   http://www.carsonfarmer.com/
> >>>      http://www.ftools.ca/
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
