[Qgis-community-team] Context sensitive help id generator
MORREALE Jean Roc jr.morreale at enoreth.net
Tue Nov 17 02:29:06 EST 2009
 Le mar 17/11/09 01:52, "Gary Sherman" sherman at mrcc.com a écrit:
> All,
> Having heard nothing from my previous email as to a preference for
> dealing with this issue, I created and committed a Python script to
> generate unique IDs for use in the context sensitive help system.
> A context id is generated from the class it is associated with (eg.
> QgsAbout).
> Please note that this is a change in the way IDs are generated
> (previous method used a Java-only solution) so existing IDs can be
> reproduced using the new script. The existing IDs can remain as
> is---they do not need to be changed unless a conflict occurs with a
> newly generated ID (I don't anticipate this happening).
> The script is in the QGIS source tree in SVN:
> ./scripts/context_help_id.py
> -gary
Sorry for the lack of answer, I had been talking about it with Tim at the hackfest but forgot to come back to you. Anyway, the python script is the best option and I'll give a try as soon as possible.
More information about the Qgis-community-team mailing list
