[Qgis-community-team] Context sensitive help id generator
Tim Sutton lists at linfiniti.com
Tue Nov 17 06:34:05 EST 2009
Hi
Thanks Gary we will put the new script to good use - I plan to go through every dialog and ensure that it has a context help I'd and a stub context help file. Maybe it won't be all done but it will be a prerequisite for 2.0.
Regards
Tim
------Original Message------
Sender: qgis-community-team-bounces at lists.osgeo.org
To: qgis-community-team at lists.osgeo.org
Subject: Re: [Qgis-community-team] Context sensitive help id generator
Sent: Nov 17, 2009 8:29 AM
 Le mar 17/11/09 01:52, "Gary Sherman" sherman at mrcc.com a écrit:
> All,
> Having heard nothing from my previous email as to a preference for
> dealing with this issue, I created and committed a Python script to
> generate unique IDs for use in the context sensitive help system.
> A context id is generated from the class it is associated with (eg.
> QgsAbout).
> Please note that this is a change in the way IDs are generated
> (previous method used a Java-only solution) so existing IDs can be
> reproduced using the new script. The existing IDs can remain as
> is---they do not need to be changed unless a conflict occurs with a
> newly generated ID (I don't anticipate this happening).
> The script is in the QGIS source tree in SVN:
> ./scripts/context_help_id.py
> -gary
Sorry for the lack of answer, I had been talking about it with Tim at the hackfest but forgot to come back to you. Anyway, the python script is the best option and I'll give a try as soon as possible.
Qgis-community-team mailing list
Qgis-community-team at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Sent from my mobile phone.
More information about the Qgis-community-team mailing list
