[Qgis-developer] Re: [Qgis-community-team] Context sensitive help id generator
Jürgen E. Fischer jef at norbit.de
Tue Nov 17 07:12:04 EST 2009
Hi Milena,
On Tue, 17. Nov 2009 at 12:33:20 +0100, Milena Nowotarska wrote:
>    As a girl (and girls doesn't like numbers) I was thinking about renaming
>    context help files to the name of a particular .ui file it is connected
>    to. That would require changes in code calling this help file, byt maybe
>    it is worth it.
Actually we could probably even derive the dialogs with help buttons from a
helper class that implements the help slot and uses the class name (ie.
metaObject()->className()) as context.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the Qgis-community-team mailing list
