[Qgis-community-team] Re: [Qgis-user] Complete information of a point created automatically.
Patrice Vetsel ubuntu at kagou.fr
Thu Apr 8 05:49:19 EDT 2010
Le jeudi 08 avril 2010 à 00:58 +0200, Goyo a écrit :
> El mié, 07-04-2010 a las 12:02 +0200, Patrice Vetsel escribió:
> > I want to use Qgis in situation on the ground. Using a plugin to center
> > a map dynamically connected to my gps. My problem is that the creation
> > of points on a shapefile layer is very restrictive if you want to fill
> > at the same time, the information (1500 points to be created). The idea
> > is to have a configurable plugin, which will, after selecting a type,
> > fill in items automatically.
> > The information is rather repetitive and rather simple. These are street
> > lights and often they are the same. Power, nature of bulbs, I'd have to
> > input every time. The best would be that the ID is automatically
> > incremented and I can select a type (Power 100W/Nature Sodium). After
> > selection by clicking on the map to add as many points as you want, and
> > the ID field is incremented and power / 100W/Sodium nature are made.
> > Have you any ideas?
> You can use custom forms (and maybe python):
> http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
Wow. It's very interesting. Thanks.
I manage to make basic. But I can not get more convenient. I tried to
create a set of checkbox. I used a GroupBox and I added 2 RadioButton
inside. But in the end it does not work. I did not find either how to
display a combo pre-filled.
Regards
Patrice Vetsel
More information about the Qgis-community-team mailing list
