[Qgis-community-team] manual status?
Otto Dassau otto.dassau at gmx.de
Fri Aug 6 04:57:13 EDT 2010
Hi Stephan,
thanks a lot! I updated the task list in the wiki.
According to that list, we have more or less updated the new features (only
a few are missing), but I think we still have some work to do. It would be
good, if all contributors can have a look at their sections and compare with
the current qgis 1.5 release. I found that there are quite a lot of small
changes to make. I will do that the next days as well.
kind regards,
 Otto
Am Fri, 6 Aug 2010 09:30:20 +0200
schrieb Stephan Holl <stephan.holl at intevation.de>:
> Hello Otto,
> Otto Dassau <otto.dassau at gmx.de>, [20100728 - 11:08:36]
> > Hi,
> > I updated the install and coding guide and prepared a pdf version -
> > so this paper is done and can be uploaded, once we have access to the
> > download server again.
> > I will now start to go through the user guide task list from top to
> > bottom. Except from Bogus, Micha and Anne, i haven't heard anything
> > about the status yet. Anyway, please update your local svn version,
> > before you make changes, because it might be that I have applied some
> > changes to "your" sections then.
> > http://www.qgis.org/wiki/ManualTasks
> > You can follow the changes I did in the ManualTasks list, of course.
> After Ottos direct ping (thanks Otto!) I have updated the OGC-parts of
> the manual a bit. I have also written a q&d Makefile for automating the
> build-process also unter linux. Hope it is helpful for someone.
> Best
> 	Stephan
> > Am Tue, 27 Jul 2010 10:51:06 +0200
> > schrieb Otto Dassau <otto.dassau at gmx.de>:
> > > Hi manual team,
> > > what is the current status of the manual updates? Can you give a
> > > short feedback what you did and what and when you can do the open
> > > sections as listed in the wiki? It would be great, if we can do the
> > > necessary updates soon to have a nice manual for the upcoming 1.5
> > > release.
> > > http://www.qgis.org/wiki/Manual_Writing
> > > Again, the list of new features that need to be updated is here:
> > > http://www.qgis.org/wiki/ManualTasks#Updates_QGIS_1.5_User_Guide
> > > please add your name, as Anne already did next to the tasks, when
> > > you updated it in the manual.
> > > if there are still any problems (e.g. working with svn), we can
> > > help.
> > > Regards,
> > >  Otto
> > > _______________________________________________
> > > Qgis-community-team mailing list
> > > Qgis-community-team at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
