[Qgis-community-team] Re: QGIS Poster
Tim Sutton
tim at linfiniti.com
Sat Dec 31 14:20:43 EST 2011
Hi Anita
On Sat, Dec 31, 2011 at 3:39 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Hi Tim,
> I'm currently working on a QGIS poster for next year's conferences. I've
> attached the current status. Now, I've been wondering what else to add and
> thought that the download stats might be nice. Would you send me the raw
> data for the last few versions so I can create a fitting diagram?
> Any ideas what else should be added?
I would suggest in the first section an additional entry:
QGIS Libraries - developer libraries that allow you to build
geospatially enabled applications using C++ and Python.
Further suggestions:
- write out 'including' in full (instead of incl. in on the fly
projection section)
- The QGIS project is holding regular developer meetings. -> The QGIS
project holds developer meetings twice a year.
- The QGIS user guide is available as PDF download and print-
on-demand book in English and German, and PDF-only in French, Italian
and Russian. -> The QGIS Desktop Application is well documented - the
user guide is available as PDF download and print-on-demand book in
English and German, and PDF-only in French, Italian and Russian.
- Users map: n.o. in legend should be no. or maybe nicer to use #
- Users map - perhaps change Data: sentance to read: Data based on IP
addresses of users accessing the QGIS 'contributed' plugin repository
between ...
For the stats I use variants of this url:
http://www.qgis.org/cgi-bin/awstats.pl?urlfilter=%2Fdownloads%2FQGIS-OSGeo4W-1.7.3-.*-Setup.exe&urlfilterex=&output=urldetail&config=qgis&framename=mainright&month=all&year=2011
You can swap the month param and version number to get month by month
stats. The spreadsheet I use to create the charts is in QGIS repo
under doc, entitled qgis-download-stats.ods - if you update it /
beautify it, feel free to send me your changed version and I will
commit it.
Its a great looking poster you are making! Thanks for the new year
wishes and right back to you and everyone on this list!
Regards
Tim
> Thank you. Have a happy new year!
> Anita
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team
