[Qgis-community-team] A note on the How do I project.
Ramon Andinach custard at westnet.com.au
Thu May 26 09:11:05 EDT 2011
Hi all,
Just a quick note to say that I've eventually finished linking the original section names of the "How do I do that in ArcGIS/Manifold?" document through to "How do I do that in QGIS?"
In theory:
1. Both pages should point to the same place.
2. The "How do I do that in QGIS?" document should be using short and fairly intuitive names.
If either of these don't seem right to anyone, please speak up so things can be made better.
For example, I'm not really sure what would be a good short name for "Select objects from one layer that are within a certain distance of an object in another layer" (which the Arc/Manifold text calls "Polygons within distance of selected features".
Both of these seem very long, and I've gone with "Select by proximity", but I've no idea if that is intuitive, or if it will translate well. Suggestions on this are welcome.
-ramon.
More information about the Qgis-community-team mailing list
