[Qgis-community-team] Wiki migration
Werner Macho werner.macho at gmail.com
Fri Nov 18 17:24:51 EST 2011
Hi Pirmin!
First it looks real good .. but it seems that some links get confused too ..
I miss the page leading to
http://hub.qgis.org/projects/wikitest/wiki/Hydrology_&#38%3B+Hydraulic+modelling
(which is in fact
http://www.qgis.org/wiki/Hydrology_%26_Hydraulic_modelling)
And there seems to be also some problem with the GUI Translation page ..
So all visible things are fine but I miss some links
For me it's not THAT bad - because I wanted to cleanup these pages a bit..
So I gotta insert the pages by hand if its too complicated to fix that
links automatically ...
(speaking that - hmm - there are some orphaned database entries
afterwards i assume)
all in all - well done
regards
Werner
On 11/18/2011 11:15 PM, Pirmin Kalberer wrote:
> Hi all,
> I've done a test run of the migration from MediaWiki to Redmine:
> http://hub.qgis.org/projects/wikitest/wiki/Page_index
> Table markup has to be fixed manually and HTML is not allowed in Redmine. Could
> you please check for other migration problems, which could be fixed in the
> migration script? Please add them to the ticket
> http://hub.qgis.org/issues/4554
> Regards
> Pirmin
> Pirmin Kalberer
> Sourcepole  -  Linux & Open Source Solutions
> http://www.sourcepole.com
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
