[Qgis-community-team] Wiki migration
Pirmin Kalberer pi_ml at sourcepole.com
Mon Nov 21 09:50:42 EST 2011
Am Montag, 21. November 2011, um 15.00:11 schrieb Otto Dassau:
> Am Mon, 21 Nov 2011 14:17:40 +0100
> schrieb Pirmin Kalberer <pi_ml at sourcepole.com>:
> > Am Montag, 21. November 2011, um 09.54:26 schrieb Otto Dassau:
> > > Am Mon, 21 Nov 2011 07:54:21 +0200
> > > schrieb Tim Sutton <tim at linfiniti.com>:
> > > > Hi
> > > > On Sun, Nov 20, 2011 at 11:19 PM, Pirmin Kalberer
> > > > wrote:
> > > > > Hi Tim,
> > > > > Am Samstag, 19. November 2011, 22.33:12 schrieb Tim Sutton:
> > > > >> On Sat, Nov 19, 2011 at 12:15 AM, Pirmin Kalberer
> > > > > wrote:
> > > > >> > Hi all,
> > > > >> > I've done a test run of the migration from MediaWiki to Redmine:
> > > > >> > http://hub.qgis.org/projects/wikitest/wiki
> > > > >> > http://hub.qgis.org/projects/wikitest/wiki/Page_index
> > > > >> > Table markup has to be fixed manually and HTML is not allowed in
> > > > >> > Redmine. Could you please check for other migration problems,
> > > > >> > which could be fixed in the migration script? Please add them to
> > > > >> > the ticket http://hub.qgis.org/issues/4554
> > > > >> Looks pretty good - I think we need to do a review of every page
> > > > >> in the wiki and consolidate where multiple pages cover the same
> > > > >> topic, remove out of date stuff and so on so what issues remain
> > > > >> could probably be sorted out manually. Do you have some idea of
> > > > >> how many wiki pages there are, in other words how big a job it
> > > > >> will be to sort out the above?
> > > > > We're talking about 320 pages. Maybe some queries (age, size) on
> > > > > the MediaWiki DB would help to find the more important ones.
> > > > Ok so it will be a bit of a job but not impossible I guess.
> > > > Regards
> > > > Tim
> > > I would help to update the pages in the new wiki.
> > If you are fine with the current migration script, I will rerun it on the
> > QGIS project itself. Before updating pages in the new wiki, we should set
> > a write lock on the MediaWiki.
> I am fine with it. Just tell me when you want to start the migration. I
> will then set the mediawiki to read-only and write an announcement to the
> list.
If I don't get a veto, I will start the migration on Wednesday 23.11. 21:00
CET.
> Am I right, that all the wiki accounts are lost then and people will need
> a valid osgeo ID? Is there something else I have to mention?
You're right. Some other (minor) things:
-RSS feed path needs update
-Watchlist is lost
-Some page names with special charact will be changed
More configs that should be updated:
-URL rewrite(redirect) of wiki.qgis.org to hub.qgis.org
-URL rewrites from http://www.qgis.org/wiki/xxx to hub.qgis.org
Who can do that?
Regards
Pirmin
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
More information about the Qgis-community-team mailing list
