[Qgis-community-team] Wiki migration
Otto Dassau dassau at gbd-consult.de
Wed Nov 23 02:20:50 EST 2011
Am Mon, 21 Nov 2011 15:50:42 +0100
schrieb Pirmin Kalberer <pi_ml at sourcepole.com>:
> Am Montag, 21. November 2011, um 15.00:11 schrieb Otto Dassau:
> > Am Mon, 21 Nov 2011 14:17:40 +0100
> > > Am Montag, 21. November 2011, um 09.54:26 schrieb Otto Dassau:
> > > > Am Mon, 21 Nov 2011 07:54:21 +0200
> > > > schrieb Tim Sutton <tim at linfiniti.com>:
> > > > > Hi
> > > > > On Sun, Nov 20, 2011 at 11:19 PM, Pirmin Kalberer
> > > > > wrote:
> > > > > > Hi Tim,
> > > > > > Am Samstag, 19. November 2011, 22.33:12 schrieb Tim Sutton:
> > > > > >> On Sat, Nov 19, 2011 at 12:15 AM, Pirmin Kalberer
> > > > > > wrote:
> > > > > >> > Hi all,
> > > > > >> > I've done a test run of the migration from MediaWiki to
> > > > > >> > Redmine: http://hub.qgis.org/projects/wikitest/wiki
> > > > > >> > http://hub.qgis.org/projects/wikitest/wiki/Page_index
> > > > > >> > Table markup has to be fixed manually and HTML is not allowed
> > > > > >> > in Redmine. Could you please check for other migration
> > > > > >> > problems, which could be fixed in the migration script?
> > > > > >> > Please add them to the ticket http://hub.qgis.org/issues/4554
> > > > > >> Looks pretty good - I think we need to do a review of every page
> > > > > >> in the wiki and consolidate where multiple pages cover the same
> > > > > >> topic, remove out of date stuff and so on so what issues remain
> > > > > >> could probably be sorted out manually. Do you have some idea of
> > > > > >> how many wiki pages there are, in other words how big a job it
> > > > > >> will be to sort out the above?
> > > > > > We're talking about 320 pages. Maybe some queries (age, size) on
> > > > > > the MediaWiki DB would help to find the more important ones.
> > > > > Ok so it will be a bit of a job but not impossible I guess.
> > > > > Regards
> > > > > Tim
> > > > I would help to update the pages in the new wiki.
> > > If you are fine with the current migration script, I will rerun it on
> > > the QGIS project itself. Before updating pages in the new wiki, we
> > > should set a write lock on the MediaWiki.
> > I am fine with it. Just tell me when you want to start the migration. I
> > will then set the mediawiki to read-only and write an announcement to the
> > list.
> If I don't get a veto, I will start the migration on Wednesday 23.11.
> 21:00 CET.
ok, I will set the wiki to read only this afternoon at 15 CET and announce
it now to the mailing lists.
> > Am I right, that all the wiki accounts are lost then and people will need
> > a valid osgeo ID? Is there something else I have to mention?
> You're right. Some other (minor) things:
> -RSS feed path needs update
> -Watchlist is lost
> -Some page names with special charact will be changed
> More configs that should be updated:
> -URL rewrite(redirect) of wiki.qgis.org to hub.qgis.org
> -URL rewrites from http://www.qgis.org/wiki/xxx to hub.qgis.org
> Who can do that?
this is Gary or Tim, I think.
Regards
Otto
> Regards
> Pirmin
More information about the Qgis-community-team mailing list
