[Qgis-community-team] Outdated PyQGIS CookBook at qgis.org
Werner Macho werner.macho at gmail.com
Fri Jan 20 07:36:33 EST 2012
It is already there ..
at the bottom ..
Last updated on Jan 20, 2012. Created using Sphinx.
so - well it's not on top but "somewhere" =)
regards
Werner
On Fri, Jan 20, 2012 at 1:32 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Can we add a "Updated on xxxx" at the top or somewhere so people can get an
> idea of the age of the info.
> 2012/1/20 Otto Dassau <dassau at gbd-consult.de>
>> Am Fri, 20 Jan 2012 13:01:01 +0100
>> schrieb Werner Macho <werner.macho at gmail.com>:
>> > Am 20.01.2012 11:52, schrieb Otto Dassau:
>> > > Hi Werner,
>> > > sorry - you can add the "updated daily" again. I updated the cronjob
>> > > on
>> > > qgis.org and updated /etc/apache2/sites-enabled/0-qgis.osgeo.org.conf
>> > > as
>> > > well. It should work again now and update the html version daily at
>> > > 22:18 Pacific Day Time, which is UTC-7h.
>> > > Regards
>> > > Otto
>> > Do you think it makes sense to add a "updated daily" there anyway?
>> > Cause if it fails (for whatever reasons) it would give room for
>> > complainment - but if there is only a "the info is there" i would
>> > personally not be upset if it's a bit outdated and wait for an update -
>> > furthermore i would be happy if i realise that it is updated on a daily
>> > base.
>> > But surely if you really want "updated daily" to be there i can add it
>> > again..
>> no, you are right - it is not necessary. We should internally keep the
>> daily
>> updates and people can follow the update date in the footer of the html
>> document.
>> Regards
>> Otto
>> > kind regards
>> > Werner
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
