[Qgis-community-team] Fw: rst conversion: problem with references
Diethard Jansen diethard.jansen at gmail.com
Mon Jul 23 21:42:07 PDT 2012
When the anchor is defined like this:
.. _table_bla:
h1   h2
bla  bla
bla  bla
Table Bla bla bla
you can refer to it like this from text like this.
See table_bla_.
This reference works, is visible, but the anchor and reference may need to
be translated as well (which is a disadvantage). I do not know of another
(better) way to make a reference to a table without using a header or
something.
regards,
Diethard Jansen
2012/7/23 Larissa Junek <junek at gbd-consult.de>
> On Tue, 17 Jul 2012 13:03:02 +0200
> Larissa Junek <junek at gbd-consult.de> wrote:
> > On Mon, 2 Jul 2012 14:02:35 +0200
> > Paolo Corti <pcorti at gmail.com> wrote:
> > > On Mon, Jul 2, 2012 at 11:22 AM, Larissa Junek
> > > > On Thu, 28 Jun 2012 16:26:18 +0200
> > > >> On Wed, Jun 27, 2012 at 4:03 PM, Larissa Junek
> > > >> > Begin forwarded message:
> > > >> > Date: Wed, 27 Jun 2012 15:59:57 +0200
> > > >> > From: Larissa Junek <junek at gbd-consult.de>
> > > >> > To: qgis-user at lists.osgeo.org
> > > >> > Subject: rst conversion: problem with references
> > > >> > Hi all,
> > > >> > while the call for a reference works fine when I deal with
> > > >> > figures, the link to a section doesn't work.
> > > >> > For example in the plugins_gps.rst I defined:
> > > >> > "... see section `defining-new-device`_" this is the call for
> > > >> > the reference
> > > >> > ".. _`defining-new-device`:" this is the reference
> > > >> > Can somebody help? What did I do wrong.
> > > >> > Kind regards,
> > > >> > Larissa
> > > >> Larissa,
> > > >> this is the correct syntax:
> > > >> a new type (see section :ref:`defining-new-device`).
> > > >> .. _defining-new-device:
> > > >> Defining new device types
> > > >> cheers
> > > >> p
> > > > Hi Paolo,
> > > > the call for the reference still doesn't work.
> > > > Maybe you have a look at the plugins_gps.rst I committed. I want
> > > > to call the reference in the same page, not in another page.
> > > > Therefore I thought that we might need another definition, like
> > > > it is described in the README.rst
> > > > I have this problem in other rst-files, too. Look forward to
> > > > finding a solution.
> > > > Cheers, Larissa
> > > Hi Larissa
> > > you need to leave an empty line just after the section declaration:
> > > (empty line here)
> > > cheers
> > > p
> > Hi Paolo,
> > this convention works fine for sections as as well as for figures. I'd
> > like to go on using it in the rst-files
> > Can you document this subject in the README and the wiki? Then we all
> > proceed the same way.
> > Thanks,
> > Larissa
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Hi Paolo and others,
> how does the call for a reference work with tables? I checked out
> several possibilities in the features_at_a_glance.rst but couldn't
> find a solution that works fine e.g.:
>  .. _table_figure_gps_tracking:
> Live GPS tracking |nix|
> | |gpstrack_main|                  |   |gpstrack_stren|
> |    |gpstrack_polar|         |
> | (a) Position coordinates         | (b) GPS signal_strength        |
> (c) GPS polar window        |
> |mActionToggleEditing| If the GPS is
> receiving signals from satellites you will see your position in
> latitude, longitude and elevation as you can see in
> Figure :ref:`table_figure_gps_tracking`.
> Can somebody help?
> Kind regards,
> Larissa
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20120724/f546ca47/attachment.html>
More information about the Qgis-community-team mailing list
