[Qgis-community-team] Fw: index in rst
Diethard Jansen diethard.jansen at gmail.com
Mon Jul 23 21:57:28 PDT 2012
I think the current indices created from latex using conversion script
should be removed and instead new indices should be created. Indices are *
visible*, but can be well hidden when used inside text.
An example:
You can use the :index:'SPIT' plugin.
The reader will find in the index *SPIT* and following it finds the
following text:
You can use the SPIT plugin.
Regards,
Diethard
2012/7/23 Tim Sutton <lists at linfiniti.com>
> Hi
> On Mon, Jul 23, 2012 at 4:49 PM, Larissa Junek <junek at gbd-consult.de>
> wrote:
> > Hi Paolo and all,
> > again I wonder what to do with the indeces in the user manual.
> > Will there be a possibility to make an index with rst? Otherwise I will
> > delete the formulations.
> Yes it is supported by sphinx - see
> http://sphinx.pocoo.org/latest/markup/misc.html#directive-index
> Regards
> Tim
> > With kind regards,
> > Larissa
> > Begin forwarded message:
> > Date: Fri, 29 Jun 2012 11:57:20 +0200
> > From: Larissa Junek <junek at gbd-consult.de>
> > To: qgis-community <qgis-community-team at lists.osgeo.org>
> > Subject: [Qgis-community-team] index in rst
> > Hi all,
> > I found several formulations for index in the plugins.rst from
> > Jean-Roc. Will there be an index in the rst user guide?
> > If yes I will insert index as well in my documents.
> > Kind regards,
> > Larissa
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20120724/2cd23728/attachment.html>
More information about the Qgis-community-team mailing list
