[Qgis-community-team] more rst conventions questions
Tim Sutton tim at linfiniti.com
Fri May 4 05:58:30 EDT 2012
Hi
On Fri, May 4, 2012 at 11:41 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi,
> for 1.
> Until now we used to add a small hint to the figure caption, e.g. (KDE) or
> (OSX) or (GNOME) .... Since we often work on QGIS Versions that are not
> installed on the OSGeo Live DVD I am not sure, if it makes sense to use
> that.
> for 3.
> This is a good idea. As for http://qgis.org/pyqgis-cookbook/ we could add
> a
> http://qgis.org/user-guide/. I can do that the next days.
Once we get it in a standardised format (I didnt look maybe it already is)
we can simply publish it to http://readthedocs.org and there is a commit
hook in github that will trigger a rebuild with each push.
Regards
Tim
> Regards
> Otto
> Am Fri, 4 May 2012 17:21:20 +0800
> schrieb maning sambale <emmanuel.sambale at gmail.com>:
> > Hi,
> > I have been editing several rst docs in the EN userguide the past
> > week.  A couple of questions before continuing:
> > 1. Updating screenshots - many of the screenshots needs to be updated
> > since there are GUI changes made.
> >   - What should be default OS for screenshots? Depending on the OS,
> > some GUI appear different (especially with OSX).
> >      I'm thinking we use Xubuntu/OSGeo Live DVD as the base OS for
> > creating screenshots, this way, we have consistent
> >      look of the screenshots within the user guide.
> > 2. File location of icons and image screenshots - Each chapter has its
> > own img directory for screenshots and icons,
> >     however, the conf.py [0] contains global image aliases for some
> > icons located in the user_guide/img directory.
> >     - Is it possible to include all the commonly used icons in
> > conf.py's rst_epilog so that these are available in all the chapters.
> >       I am only using the English version of QGIS so, I'm not sure
> > whether icons are different with the other languages.
> > 3. Compiled rst available - do we have a regular build of the rst
> > documentation available already? I do compile my own, but it would be
> > good
> >     if we have a daily build available in the qgis.org so that we can
> > start linking QGIS questions to sections of the manual.  Even as a
> > working draft.
> > [0]
> https://github.com/qgis/QGIS-Documentation/blob/master/user_guide/conf.py#L90
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20120504/2d6bf2a8/attachment.html
More information about the Qgis-community-team mailing list
