[Qgis-community-team] rst2pdf.pdfbuilder (exception: No module named roman)
Paolo Corti pcorti at gmail.com
Sat May 19 11:13:28 EDT 2012
On Sat, May 19, 2012 at 2:22 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi,
> I wanted to do some rst conversion but fail with error message:
> Could not import extension rst2pdf.pdfbuilder (exception: No module named
> roman)
> It seems necessary to upgrade Sphinx v1.1.2 which I think is not that old.
> Is it always necessary to have the latest version available to be able to
> work on the documentation? Or is there another work around?
Hi Otto
It seems to me that your system is missing rst2pdf, which is based or ReportLab.
If you do a pip install rst2pdf in your virtualenv or system it should
start working
ciao
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the Qgis-community-team mailing list
