[Qgis-community-team] enumeration for figures
Paolo Corti pcorti at gmail.com
Thu Oct 11 02:40:40 PDT 2012
On Thu, Oct 11, 2012 at 11:35 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Am Thu, 11 Oct 2012 09:47:38 +0200
> schrieb Paolo Corti <pcorti at gmail.com>:
>> On Thu, Oct 11, 2012 at 9:40 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
>> > thank you, Paolo!
>> > The manual version at http://documentation.qgis.org is not the latest. I
>> > updated the build.sh script which is started by the sphinx conjob. It now
>> > starts the two scripts pre_translate.sh and post_translate.sh in the
>> > scripts folder to create the translation files and the documentation. It
>> > doesn't build yet, but I can/will have a look later, when I have a
>> > little break.
>> Hi Otto,
>> cannot check it right now, but as far as I can remember the original
>> build script could perform all of this task.
>> thanks for fixing stuff, though ;)
>> cheers
>> p
> Hi Paolo,
> I get an error message on debian, "Builder name gettext not registered". Do
> you know, what package I need to install to have in on board?
> On the qgis server sphinx v0.6.6 is installed
sphin 0.6.6 is obsolete, it looks you are using the global system one.
You need to use the virtualenv, where latest sphinx is installed.
The build script is in fact activating the virtualenv and doing the
whole process
cheers
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the Qgis-community-team mailing list
