[Qgis-community-team] Redmine/wiki help
Ramon Andiñach custard at westnet.com.au
Tue Oct 23 15:46:31 PDT 2012
On 15/10/2012, at 15:52 , Ramon Andiñach wrote:
> Hi,
> Eventually putting in a bit of time to fix up some of the pages I'd worked on before the migration to Redmine.
> I've a couple of questions I would like some help with.
> I'm having problems working out what to replace <small> text </small> with?
> (I'd been using it for captions)
> I'm also not seeing a way to resize embedded images. Is that possible?
> (something like the width tag for HTML images)
> -ramon.
Following up,
My reading of this page: http://www.redmine.org/projects/redmine/wiki/RedmineTextFormatting
is that -- text -- is the equivalent of <small> text </small> and that both should work. But neither does.
Equally, I'm noticing that formulations such as "Redmine web site":http://www.redmine.org do not work as advertised.
Is the QGIS redmine non-standard in some way?
On a related topic, if I've loaded up images that I don't need anymore is there a way to remove them?
-ramon.
More information about the Qgis-community-team mailing list
