[Qgis-community-team] Antw.: doc translation
Otto Dassau dassau at gbd-consult.de
Sun Apr 14 05:40:42 PDT 2013
Hi Matteo,
I will have a look tomorrow and integrate it to the git file.
And you need to install also pushd and pops, if that is available as a deb. The tex2dvi is no problem.
Regards
Otto
----- Reply message -----
Von: "matteo" <matteo.ghetta at gmail.com>
An: <qgis-community-team at lists.osgeo.org>
Betreff: [Qgis-community-team] doc translation
Datum: So., Apr. 14, 2013 13:31
Hi guys,
I still have the problem to build the html file with the script
post_translate. Someone can help?
scripts/post_translate.sh: 77: scripts/post_translate.sh: pushd: not found
/usr/bin/texi2dvi: pdflatex exited with bad status, quitting.
mv: l'obiettivo "1.8-UserGuide-it.pdf" non è una directory
scripts/post_translate.sh: 84: scripts/post_translate.sh: popd: not found
p.s. Nobody add something to the git command list I wrote and post
yesterday. Wasn't it good? Do you mean something else?
Cheers,
Matteo
Qgis-community-team mailing list
Qgis-community-team at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130414/df670522/attachment.html>
More information about the Qgis-community-team mailing list
