[Qgis-community-team] icons in the conf.py
Otto Dassau dassau at gbd-consult.de
Fri Aug 9 04:45:23 PDT 2013
Hi Larissa,
I checked and it seems that icons and figures are not updated correctly
anymore in the 2.0 manual. Most of the figures from Alexandre don't appear,
although they are integrated correctly.
I guess we need to check build scripts ... is it possible that it has
something to do with the new theme?
Regards
Otto
Am Tue, 6 Aug 2013 16:27:12 +0200
schrieb Larissa Junek <junek at gbd-consult.de>:
> Hello,
> I've found that using the workaround for the user manual
> icons that I define in the conf.py aren't recognized. If I want to use
> the icons in the rst files not the icon but the code is visible.
> Does someone know if this is because of the pre_translate or
> post_translate scripts?
> Kind regards,
> Larissa
More information about the Qgis-community-team mailing list
