[Qgis-community-team] new website repo
Jeffrey Johnson jjohnson at opengeo.org
Fri Aug 23 13:40:40 PDT 2013
Does make sense to leave the existing docs in place where they are for
now until this new setup is ready for prime time.
On Fri, Aug 23, 2013 at 1:38 PM, Jeffrey Johnson <jjohnson at opengeo.org> wrote:
> I'm going to spend some time to look into the options for customizing
> the base sphinx_bootstrap theme, but it looks to be fairly
> straightforward.
> Also, I used this library https://pypi.python.org/pypi/sphinx-intl to
> do the basic i18n setup and will spend more time to make sure
> everything is perfectly setup for localization. Seems to make sense to
> me to use transifex to manage the process, but can be done manually as
> well.
> A designer on our team (cc'd) will come back with some proposed
> wireframes for the 'new' site next week sometime for everyone to
> review.
> Glad I/we can finally offer a hand on these things.
> Jeff
> On Fri, Aug 23, 2013 at 1:34 PM, Richard Duivenvoorde <richard at duif.net> wrote:
>> Hi List,
>> We have a separate repo now for the website:
>> https://github.com/qgis/QGIS-Website
>> it is build in /var/www/qgis_new_web/QGIS-Website and viewable via
>> http://new.qgis.org/html/ for now
>> it is vanilla sphinx with the 'sphinx_bootstrap_theme' theme created by
>> Jeffrey Johnson
>> from here we should hack design, i18n and the building scripts into it
>> again.
>> Jeffrey asked somebody to come up with a design also. He will help/create
>> with the site also.
>> If we are sure that this is the website route to go I will remove the
>> website-sources from the documentation repo. But untill then I think to just
>> keep them there for now.
>> Regards,
>> Richard
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
