[Qgis-community-team] pull req of translated files
Otto Dassau dassau at gbd-consult.de
Wed Jan 9 08:50:43 PST 2013
Hi Matteo,
I think you only need to run
pre_translate it
post_translate it
if you work with the italian translation. And what does the build.log
file say?
Regards
Otto
Am Wed, 09 Jan 2013 17:39:15 +0100
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi guys,
> right now I made two pull requests of the Italian translated files
> (those with the syntax problem).
> I compiled the build.sh so I can see if the corrections I made were
> right, so:
> - although I translated all the strings of the po files, when I
> generated the html files (with build.sh), in those files some parts
> remain untranslated
> - the build.sh needs a lot of time because it generates the html file
> for all the languages. I changed the pre_ and post_translation scripts
> so I can make html files only for the language I want. Maybe should I
> add how to make these changes in the howto file? Can be useful?
> Regards
> Matteo
More information about the Qgis-community-team mailing list
