[Qgis-community-team] pull req of translated files
matteo matteo.ghetta at gmail.com
Thu Jan 24 09:46:16 PST 2013
On 24/01/2013 18:42, Otto Dassau wrote:
> Am Thu, 24 Jan 2013 18:36:27 +0100
> schrieb matteo <matteo.ghetta at gmail.com>:
>>> Hi,
>>> have you checked again? Does it work now?
>> Hi Otto,
>> sorry for the delay... anyway I checked all the files translated (the
>> entire introduction folder and the working with projections file), and
>> it works!!!!
>> I generated the html files and except for the strings that begins with
>> a)..., all the strings have been translated...
>> So if you want you can update the italian manual sections (how often the
>> files on github are "transformed" in html?).
> On the qgis server we currently "git pull" 3 times a day from github and
> build the manuals as html and pdf. You can find the current it translation
> already here:
> http://documentation.qgis.org/html/it/docs/user_manual/index.html
Thanks Otto.
I'm right now commiting the last syntax corrections and when Paolo will
merge my pull requests you should have the clean and completed files.
Cheers
Matteo
More information about the Qgis-community-team mailing list
