[Qgis-community-team] Qgis-community-team Digest, Vol 64, Issue 2
Alexandre Neto senhor.neto at gmail.com
Thu Jul 4 15:34:40 PDT 2013
Hello there,
I'm in charge of taking the screenshots. Just put a title for each image
that represent what you want to be shown and I will do my best based on
your text. After I pull request the screenshots I will inform you, and you
are free to send me an email or a git message if you have a better idea.
Best Regards,
Alexandre Neto
On Thu, Jul 4, 2013 at 10:20 PM, Hien TRAN-QUANG
<hien.tranquang at gmail.com>wrote:
> Hello,
> I took a week of vacation just after your reply, and I've been in quite a
> rush lately. But now everything is becoming ok. I began to update the print
> composer chapter. As I test and check on the way, I found a bug for which I
> filled a report 2 days ago.
> I planned to completed a little more text before I pull a request, but if
> you prefer, I can pull now my work in progress. Maybe it is easier for
> everyone as one can see I'm still alive.
> Just one question : do I need to take screen caps or is someone in charge ?
> Regards.
> Hien.
> Message: 1
>> Date: Thu, 4 Jul 2013 09:48:10 +0200
>> From: Otto Dassau <dassau at gbd-consult.de>
>> To: qgis-community-team at lists.osgeo.org
>> Subject: Re: [Qgis-community-team] Looking for help to update the
>>         englisch manual (Otto Dassau)
>> Message-ID: <20130704094810.6c15e9f5 at nature.speedport.ip>
>> Content-Type: text/plain; charset=UTF-8
>> Hi Hien,
>> I haven't heard from you again after I sent you the list of features, that
>> need to be added to the print composer? Are you still interested to work
>> on
>> it? Do you have questions or problems to start?
>> Kind Regards
>> Otto
>> Am Fri, 14 Jun 2013 12:19:00 +0200
>> schrieb Otto Dassau <dassau at gbd-consult.de>:
>> > Hi Hien,
>> > if you have a look at the manual task list:
>> > http://hub.qgis.org/wiki/17/ManualTasks#Updates-QGIS-20-User-Guide
>> > There are several features listed for chapter "print composer" at the
>> > bottom now. I added your name to the lines and extended the list to
>> what I
>> > think needs to be added/updated for the print composer.
>> > * snap to left/mid/right coordinates of other items when moving composer
>> >   items for alignment
>> > * custom linestyle for composer grid
>> > * add support to SVG images from url
>> > * new element "add html frame"
>> > * Support for creation of map atlasses (new tab)
>> > * possibility to show composer map grid coordinates in
>> > degree/minute/seconds
>> > * Multipage compositions
>> > * split legend in several columns
>> > * Display rectangle of another composer map (overview map)
>> > * Zebra style for composer grid (black/white pattern at borders)
>> > * New Rendering menu with several blending modes (here Larissa has more
>> >   information)
>> > * General new structure of the item property tab for all elements
>> > * describe item ID feature in element tab (was already in 1.8)
>> > I would suggest you start using the master branch and send pull requests
>> > for your changes, so we can have a look. Is that ok for you?
>> > Thank you very much for your help and don't hesitate to ask, if there
>> are
>> > questions.
>> > Regards
>> > Otto
>> > Am Fri, 14 Jun 2013 11:40:55 +0200
>> > schrieb Hien TRAN-QUANG <hien.tranquang at gmail.com>:
>> > > Hello,
>> > > I'm replying to Otto's call for help on the QGIS users mailing list.
>> > > I just started helping translating the 1.8 manual in French at FROG's
>> > > Code Sprint a few days ago.
>> > > I would like to help you release new QGIS 2.0 as soon as possible. So
>> > > here I am.
>> > > My preferences go to print composer, so if someone can tell me which
>> > > features I can work on.
>> > > Hien TRAN-QUANG
>> > _______________________________________________
>> > Qgis-community-team mailing list
>> > Qgis-community-team at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> Geoinformatik B?ro Dassau - http://www.gbd-consult.de
>> FOSSGIS consulting , training , support  and analysis
>> Ackerstrasse 144c  ,  D - 40233 D?sseldorf  , Germany
>> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
>> Community Advisor - QGIS Project Steering Committee
>> End of Qgis-community-team Digest, Vol 64, Issue 2
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130704/a4bfc2bf/attachment.html>
More information about the Qgis-community-team mailing list
