[Qgis-community-team] screenshots user manual
Larissa Junek junek at gbd-consult.de
Wed Jun 19 03:56:32 PDT 2013
Hi Werner!
Yes, good idea. This definitely improves the Look and Feel of the
plugin. So I will make a screenshot after your improvement.
Kind regards,
Larissa
> Hi Larissa!
> Bevore doing any screenshots from Topology Checker ..
> I did not have time yesterday but I wanted to add the usual + and -
> signs to the buttons or at least change Add New Rule to just "Add
> Rule" And still the two buttons of Add and Delete should change
> place .. Probably I will have time today evening to do that ..
> What do you think about that?
> kind regards
> Werner
> On Wed, Jun 19, 2013 at 12:02 PM, Larissa Junek
> <junek at gbd-consult.de>wrote:
> > Hello,
> > I currently work on the section "Topology Checker plugin" and want
> > to insert a screenshot into the text. By doing so there will be
> > multiple kinds of screenshots in the QGIS user manual 2.0.0.
> > because also Alexandre Neto creates screenshots for the new user
> > manual. Are you o.k. with the procedure? I want to continue working
> > quickly. Thanks.
> > Kind regards,
> > Larissa Junek
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
More information about the Qgis-community-team mailing list
