[Qgis-community-team] Transifex updates
Tim Sutton lists at linfiniti.com
Tue Mar 19 23:41:22 PDT 2013
Hi All
Unless there are other pending issues, I think I am pretty much
finished configuring and understanding transifex for the
QGIS-Documentation repo. Here is the current status:
* The transifex project reflects documentation for v1.8 of the manual
* Last night I pushed all existing translations up to the project so
it should reflect the current translation state of each language.
Please take a look at your language and see if this is indeed the
case.
* I've written a script to automate the process of pushing language
files - this is available under scripts/create-transifex-resources.sh
and is backported to both 1.8 and master branches.
* To 'download' translation updates to the git repository Otto or
other git committers should follow this procedure:
Things that only need to be done once:
sudo pip install transifex-client
cd /tmp
tx init
Take the defaults and enter your password when prompted. Note that you
password is stored in clear text in ~/.transifexrc
Now go to your local QGIS-Documentation repo and do this everytime you
want to fetch updates:
tx pull
git status
git add [any new language files)
git commit -m "Updated i18n resources from Transifex" i18n
To push any local changes to transifex (for example if you did
translation work locally using QtLinguist):
I would greatly appreciate if someone could test the above procedures
and then transpose the information above into the README.rst file in
the base of the documentation tree.
I am now going to go on and do the same for the QGIS Training manual
and the QGIS application itself.
Best regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
