[Qgis-community-team] manual in pdf
    NUIMURA, Takayuki
    nuimura at nagoya-u.jp
    Mon Oct 14 20:23:46 PDT 2013
Hi Richard,
Thank you very much for quick responce for my request about japanese
pdf. I have checked pdf file, you generated.
It still has following two problems:
[1] no index
[2] inappropreate image file (too large)
I have downloaded resources, you updated, and compiled pdf based on
proper procedure (make pdf LANG=ja).
I have found following two solution for above two problems by trial and
error.
[1] adding third platex command.
[2] replacing find command to simple ebb with regular expression. And -x
option is also not necessary.
Modified source is:
	@-if [ $(LANG) = "ja" ]; then \
		cd $(BUILDDIR)/latex/$(LANG); \
		ebb *.png \
		platex -interaction=batchmode QGISUserGuide.tex; \
		dvipdfmx QGISUserGuide.dvi; \
	else \
		texi2pdf --quiet QGISUserGuide.tex; \
	fi
Could you update Makefile?
You can check correctly generated japanese pdf:
https://dl.dropboxusercontent.com/u/870568/foss4g/QGIS-testing-UserGuide.pdf
On 10/13/2013 03:03 AM, Richard Duivenvoorde wrote:
> On 12-10-13 11:09, NUIMURA, Takayuki wrote:
>> In Japanese LaTeX community, it is known that, pdftex (pdflatex) cause
>> error for compilation with Japanese font.
>> Hence, we Japanese use platex + dvipdfmx command as alternative of pdftex.
>> And platex command cannot read png image format. A bounding box file
>> (*.bb) must be generate before compilation.
> Hi,
> we are not using the post_translate.sh anymore, but the Makefile:
> https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L101
> as you see I changed it to reflect your changes, and indeed on my laptop
> (Debian testing) locally I can generate both russian and japanese with
> platex, after I installed-lang-cjk
> 	sudo apt-get install texlive-lang-cjk
> and instructed ebb to generate bbx files (via -x)
> But on qgis-server we run squeeze, and this package is not available.
> There only ptex provides platex.
> But I cannot get platex get to generate pdf there. It stops with some of
> these errors:
> Package inputenc Error: Unicode char \u8:�^^80^^8b not set up for use
> with La
> TeX.
> LaTeX Font Warning: Font shape `JY1/gt/bx/it' undefined
> (Font)              using `JY1/gt/bx/n' instead on input line 120.
> ! Package inputenc Error: Unicode char \u8:リ� not set up for use with
> LaTeX.
> See the inputenc package documentation for explanation.
> Type  H <return>  for immediate help.
> l.120 \tableofcontents
> I tried to install japanese fonts, but that did not help. Google seems
> to think my latex is just too old???
> I uploaded the ja and ru generated on my laptop ere:
> http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ja.pdf
> http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ru.pdf
> Are these ok?
> Please let me know if somebody can help me to fix the generation of
> pdf's on the qgis server.
> Regards,
Takayuki NUIMURA
Graduate School of Environmental Studies, Nagoya University
F3-1(200), Furo-cho, Chikusa-ku, Nagoya 464-8601, Japan
Phone/FAX:+81-52-789-3477
E-mail: nuimura at nagoya-u.jp
Skype: t_nuimura
More information about the Qgis-community-team
