[Qgis-community-team] We need help updating the qgis user guide for version 2.2
luca.casagrande at gmail.com luca.casagrande at gmail.com
Tue Apr 8 06:34:56 PDT 2014
2014-04-08 9:38 GMT+02:00 Richard Duivenvoorde <richard at duif.net>:
> On 07-04-14 17:14, luca.casagrande at gmail.com wrote:
>> Hello everybody,
>> I almost completed the printer section, but I need to add some new
>> icons (i.e. the Atlas Preview toolbar).
>> I searched inside the resources/en/docs/common folder, but I couldn't find them.
> Hi Luca,
> can you give an example of an icon you are searching for? Eg by
> providing a link from the online docs.
> if you are busy in master version of QGIS-Documentation, images should
> be here:
> https://github.com/qgis/QGIS-Documentation/tree/master/resources/en/docs/user_manual
> and then in the folder with the same name as your rst files are in.
> Also note that the documentation use a lot of 'abbreviations' for
> images, and those are defined in the conf.py file:
> https://github.com/qgis/QGIS-Documentation/blob/master/source/conf.py#L193
> Hope this helps,
Hello Richard,
thanks for your message.
I am looking for the icons of the the Atlas toolbar in the Print Composer.
Regards
Luca
More information about the Qgis-community-team mailing list
