[Qgis-community-team] use of 'abbreviation' in documentation
Otto Dassau dassau at gbd-consult.de
Mon Apr 14 11:51:33 PDT 2014
Hi Richard,
I don't think there is another reason for using the abbreviations. It is
just shorter inside the text. So if it makes the build faster, we could
change it. And I guess we could change it for almost all icons inside the
docs, since they are mostly used only once.
Regards
Otto
Am Mon, 14 Apr 2014 15:17:08 +0200
schrieb Richard Duivenvoorde <richard at duif.net>:
> Hi Otto, Larissa,
> (writing to you as I think you are most into this...)
> Currently most doc writers use the 'abbrevation' scheme to insert images
> into documentation.
> That is, they add an abbrevation in the rst_epilog property:
> https://github.com/qgis/QGIS-Documentation/blob/master/source/conf.py#L193
> and then use that abbreviation in the rst source of the docs.
> BUT: this list of 'replacements/abbreviations' is getting longer and
> longer, and it seems to me that it slows down the build. Another point
> is that the conf file is getting bigger and bigger, with replacements
> for images which are maybe used once or twice in the whole documentation
> (like most mAction*** images).
> So my question:
> - is there another reason to do this the way we do it now? I could think
> of for example that it is needed for the Latex output, or maybe because
> of the reference linking or so??
> If not: should we try to use the abbrev ONLY for those image which
> really are being used >3 times throughout the docs or website? Or images
> we are being reused over different websites (like docs and website).
> Comments?
> Regards,
More information about the Qgis-community-team mailing list
