[Qgis-community-team] Training manual: Processing
Richard Duivenvoorde richard at duif.net
Wed Apr 16 13:01:57 PDT 2014
Hi Paolo,
I'm not into the details of processing, but note that the 'master'
version of the Documentation should be in sync with 2.2/stable version
of QGIS, NOT with current master version of QGIS.
That is because currently the master version of documentation will be
branched to 2.2 in hopefully short time.
AFTER that master docs are about master QGIS again...
Hope this makes sense :-)
Regards,
Richard
On 04/16/2014 06:40 PM, Paolo Cavallini wrote:
> Hi all.
> I'm revising the training manual, and I have some doubts about the
> Processing section
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/training_manual/processing/vector_calculator.rst
> this seems outdated in ref to the current exp version of Processing; the
> Python syntax does not seem to be recognized any more, so
> float(MALES) / FEMALES does not work. Should I replace it with
> 1.0*MALES / FEMALES
> Same for
> 'male' if MALES > FEMALES else 'female'
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/training_manual/processing/extents.rst
> the command Shapes to grid leaves out the first basin (ID=0): should I
> change the IDs? The Rasterize command does not create NULLs, and puts 0
> to NULL
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/training_manual/processing/html.rst
> in the output, the layer and field names are missing: should I open a
> ticket?
> * have found some problem with projections not being recognized, so I'll
> be adding .qpj: objections?
> All the best.
More information about the Qgis-community-team mailing list
