[Qgis-community-team] QGIS Arabic Translation
Werner Macho werner.macho at gmail.com
Sun Jan 19 01:20:35 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
Thanks Richard for explaining..
The only answer that is left for me is that there are 2 others that
actually did some translations:
Assem Kamal <prog.assem at yahoo.com>, and
Latif Jalil (email missing),
but unfortunately I have not heard anything from them since 2009.
So I have to say that I think you are currently the only arabic
translator (Thanks again for taking this task)
kind regards
Werner
On 01/18/2014 03:19 PM, hosham22 wrote:
> Yes I meant by software modules the qgis, I will do as you taughld
> me. But what if I want to translate the documents, what I have to
> do?
> Sent from Samsung Mobile
> -------- Original message -------- From: Richard Duivenvoorde
> <richard at duif.net> Date: To: hosham munier
> <hosham22 at hotmail.com>,Werner Macho
> <werner.macho at gmail.com>,qgis-community
> <qgis-community-team at lists.osgeo.org> Subject: Re: QGIS Arabic
> Translation
> On 18-01-14 10:32, hosham munier wrote:
> Hi Hosham,
> I try to give anwers below:
>> -What I have to do if I want to translate the documents also in
>> addition to the software modules(I already work with)?
> Not sure what you mena with the software modules you are working
> with. Please explain.
> Guessing you mean QGIS: if you use Linguist to translate, you can
> make from the .ts file a .qm file. The qm file is the format that
> the QGIS program is actually using to change the strings in the
> program.
> Load the ts file in Linguist and then via menu File and then
> Release you will be asked where to save it. You have to find out
> where QGIS loads the qm files from (on Linux they are in your
> install folder, and then share/qgis/i18n folder). On windows search
> for qgis_ar.qm, it should be somewhere in your QGIS install. If you
> just copy your release (=qgis_ar.qm file) over the file that is
> there and open QGIS again, it will open YOUR qm file.
>> -if any one work with me in Arabic translation or not?
> I'm not aware of others doing arabic translation. Werner do you
> know?
>> -the Arabic translation  file I already sent is work or not?
> Yes it is already in Github. I'm not sure if they show up in the
> nightlies though, because we do not run the scripts every day to
> compile the .ts file to .qm files in the master repo.
> HTH. If not, just ask again :-)
> Regards,
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iEYEARECAAYFAlLbmN0ACgkQDAH1YiCxBgluiwCeK1ZPwWTFimZFLU3tiW3Q2EE2
ISAAmwTXtIWXWR0Gy8h9BQJPkj7TG+DB
=/4QN
-----END PGP SIGNATURE-----
More information about the Qgis-community-team mailing list
