[Qgis-community-team] user manual 2.0 good news
Alexandre Neto senhor.neto at gmail.com
Wed May 7 17:35:20 PDT 2014
Hello all,
After some more testing and some help from the texi2dvi mailing list[], I
think I finally found out the solution for our image size and resolution
for both PDF and HTML.
The problem did not lay on the configuration file or texi2pdf settings but
in the image files itself. All that is needed to do is to open the
screenshots in GIMP and change their print resolution from 72 dpi (the
origina resolution of screens), to something like 135dpi (we can decide
which the more suitable resolution). Also, its needed to remove the width
size settings form the rst files for those images.
The good news are that images will show at their original resolution in
HTML (below maxwidth of the page) and at a different (more suited
resolution) in the PDF.
Please check my Pull Request
https://github.com/qgis/QGIS-Documentation/pull/219 and see how it builds
both html and PDF before you accept it
On Tue, Nov 5, 2013 at 3:57 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi Richard,
> I adapted image size again and the pdf and html look ok to me. The problem
> is not solved yet, how to automatically optimize figure size and resolution
> for html and pdf build. But to whom should we wait to solve this?
> I don't think we should stop translation any longer, now that the content
> is up-to-date.
> Regards
> Otto
> Am Tue, 05 Nov 2013 16:48:43 +0100
> schrieb Richard Duivenvoorde <richard at duif.net>:
> > On 05-11-13 12:16, Otto Dassau wrote:
> > > what about "releasing" the current manual as QGIS 2.0 and branch for
> > > translation? I think we should not wait any longer. I fixed/changed
> some
> > > more things / figure sizes for the pdf and I think it looks ok.
> > > We could try to improve the figures for the next version.
> > > What do yo think? Richard, would it be ok for you to create translation
> > > branch for 2.0 and prepare it for transifex, etc?
> > Hi Otto,
> > sure fine, but is all work on images in pdf and html now ok?
> > I just did 'make world' on the server, so within some time this url
> > http://docs.qgis.org/testing/
> > should show you current status. (by the way:
> > http://docs.qgis.org/2.0 is currently pointing to exact the same place,
> > but will be updated after branch to point to a 2.0 build of the docs)
> > This url:
> > http://docs.qgis.org/testing/pdf/
> > should contain pdf's dated on the 5th of November.
> > Please check if these are all ok.
> > If OK, we could branch 2.0,
> > I'll run 'make pretranslate' on it, which will generate pot/english po
> > files which then can be pushed to Transifex.
> > At that moment the Transifex documentation project wil NOT be the
> > translations of master anymore, but the translation of 2.0
> > To be sure nobody we can remove all .po files (translations) from master
> > branch, but that means that even current translations will NOT be
> visible.
> > So
> > at http://docs.qgis.org/testing/
> > will only be available in english...
> > Not sure if that is what we want though..
> > Regards,
> > Richard
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20140508/35bd52a8/attachment.html>
More information about the Qgis-community-team mailing list
