[Qgis-community-team] translation question
Otto Dassau dassau at gbd-consult.de
Thu May 22 07:00:16 PDT 2014
Hi Werner,
thanks a lot, seems to work :)
Regards
Otto
Am Thu, 22 May 2014 15:03:24 +0200
schrieb Werner Macho <werner.macho at gmail.com>:
> Hi Otto!
> If there is one single file containing the source you can upload it by
> more or less a trick ..
> Download the original translation file of that file - rename your
> translation after that file and upload the translation again ..
> at least this trick worked for me with one file ..
> bad luck if it is splitted into tons of files - too much work to do it
> that way than..
> regards
> Werner
> On Thu, May 22, 2014 at 3:01 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> > Hi Richard,
> > we have an old translation from QGIS manual 1.8 (the GPL and FDL
> > appendix) and this translation is not in transifex. Probably, because it
> > was not translated with transifex at that time.
> > Is it possible to just upload the 1.8 .po files to transifex? Would that
> > work? I remember it would not be recognized correctly?
> > Regards
> > Otto
More information about the Qgis-community-team mailing list
