[Qgis-community-team] release of qgis 2.6 documentation
Ramon AndiƱach custard at westnet.com.au
Mon Nov 17 01:43:37 PST 2014
Manage items done in Pr #372.
I've added in a bit about the changes to locked layers, and I think that maybe a picture of the items tab showing some locked and unlocked items might be helpful - any thoughts?
I've also made the change mentioned below, but I note that my window manager treats that as move window, and I need ctrl and alt. I'm not sure how widespread this is or if this needs handling as a note.
These's also a very brief outline of creating/moving/deleting guides because I couldn't see one elsewhere.
-ramon.
> On 17 Nov 2014, at 16:12, Ramon Andiñach <custard at westnet.com.au> wrote:
> Thanks Andreas,
> I'll change it from ctrl to alt in the bits I'm doing.
> -ramon.
>> On 17 Nov 2014, at 15:18, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi Ramon,
>> The ctrl-key doesn't do anything during resize, but pressing the shift-key constraints the ratio and pressing the alt-key scales from the center.
>> For arrows (lines), pressing the shift-key constraints to 45 degree angles, incl. horizontal and vertical.
>> Andreas
>>>> On 17.11.2014 08:11, Ramon Andiñach wrote:
>>>> On 15 Nov 2014, at 4:09, Diethard Jansen <diethard.jansen at gmail.com> wrote:
>>>> Hi there,
>>>> We need a bit more time, another week, to finish the documentation for 2.6.
>>>> When we decide to put it into translation, a branch for 2.6 will be created and that version will be final, there is no chance to improve the documentation for 2.6 afterwards,
>>>> Please read the testing version and provide issues on github to improve the documentation before release.
>>> Hi,
>>> I have some bits of time today and tomorrow, so I'm looking through the print composer bits which is where most of the gaps on the wiki seem to be.
>>> Is this a sensible place to be looking?
>>> and
>>> On the computer in front of me, resizing an object holding ctrl doesn't do anything special. Is this right?
>>> (I've only got a 2.5 from inside the feature freeze, so maybe it should be working.)
>>> -ramon.
>>> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
