[Qgis-community-team] See the doc images at github (or not)
Richard Duivenvoorde richard at duif.net
Tue Nov 10 03:08:47 PST 2015
Yep... just need some time to dive into it..
Richard
On 09-11-15 14:49, DelazJ wrote:
> Hi,
> Richard, do you still plan on this?
> 2015-06-09 10:29 GMT+02:00 DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>>:
>     Hi,
>     I have no skills on this but I think it'll indeed be very helpful to
>     display images while writing/updating documentation files in github
>     So, if it's easy to do and there is no side effect, +1 from me
>     2015-06-08 11:50 GMT+02:00 Richard Duivenvoorde <richard at duif.net
>     <mailto:richard at duif.net>>:
>         Hi List,
>         if you look at the rst files in our documentation repo, you will
>         only
>         see text, NOT the images:
>         https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/training_manual/forestry/map_georeferencing.rst
>         It appears that this is because we keep our images at
>         /resource/en/...
>         and copy them into /static during the build, to be able to have
>         localized images....
>         But after seeing the foss4glabs (markdown) sources in their
>         github repo:
>         https://github.com/FOSS4GAcademy/GST101FOSS4GLabs/blob/master/Module%205%20Lab/QGIS%202.8/Module%205%20Lab.md
>         I wondered if it would also be possible that we showed our
>         images in the
>         rst-view of github.
>         It indeed is easy: just copy the english (en) image directory to a
>         directoy 'static' and all images which are referenced like:
>         .. image:: /static/training_manual/forestry/f_1.png
>         are viewable now at github (this is a temporary fork to be able to
>         fiddle a little with this, note only foresty images are copied):
>         https://github.com/rduivenvoorde/QGIS-Documentation/blob/master/source/docs/training_manual/forestry/map_georeferencing.rst
>         as you can see, it is only plain images you see, the images
>         which are
>         'shortcuts' from conf.py you will not see.
>         But I think it is valuable to see the images immediately in
>         Github, it
>         makes spotting 'old' images much easier for doc writers/editors.
>         The only reason the images currently are not in '/static'
>         dir/tree is
>         that we want the building process to be able to FIRST copy the
>         english(original) images in the /static dir during build and
>         THEN copy
>         (optional) localized images over it during a localized build.
>         But there is not reason to not put the english images already in the
>         '/static' dir (so moving them from /resource/en/... to /static) and
>         change some steps in the build proces
>         So please comment on the following proposal:
>         - we move the resource/en directory to /static
>         - change some steps in the build scripts
>         - we could do the same for the website...
>         Comments?
>         Regards,
>         _______________________________________________
>         Qgis-community-team mailing list for organizing community
>         resources such as documentation, translation etc..
>         Qgis-community-team at lists.osgeo.org
>         <mailto:Qgis-community-team at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
