[Qgis-community-team] New screenshots
Alexandre Neto senhor.neto at gmail.com
Fri Oct 23 03:34:08 PDT 2015
I have used the ubuntu with unity and the default "ambience" theme. For
screenshots of QGIS main window and composer I have set it to show menus on
the window (not the default in unity).
For setting the dpi, you need to open the screenshot on GIMP (or similar)
and set the print resolution (image > print size) and save. This can also
be done in batch by using ImageMagick convert command. I believe that the
syntax is something like this:
Alexandre
Radim Blazek <radim.blazek at gmail.com> escreveu no dia sex, 23/10/2015 às
11:13:
> On Fri, Oct 23, 2015 at 11:56 AM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > Some users manual versions ago (2.2 I think), it was considered that it
> > would be nice to have all screenshots using the same OS, because by that
> > time there were way to many different OS, zoom levels, etc..., And the
> > document just looked ugly and poorly formated.
> > By that time, I have volunteered myself and created/updated most
> screenshots
> > using ubuntu,
> So that is probably currently the preferred system. Can you specify it
> more precisely?
> Gnome/KDE, theme, decorations...?
> > also worked around some setting to stabilize the images
> > resolution to look good both on the site and in PDF (the reason behind
> the
> > 135 dpi recommendation).
> If I take a screenshot, how should I fix the resolution? Is there a
> command?
> Radim
> > I have also maintained most of the screenshots in
> > the 2.6 and 2.8 version. Unfortunately, I wasn't able to do it for 2.10,
> an
> > probably wont have time to do it for 2.12 either.
> > Anyway, I believe that the guidelines are not all mandatory, and like
> > Richard said, better to have a screenshot with a different OS that not
> have
> > a screenshot at all. So I would recomend that people just create the
> > screenshots following as many guideline as they can. Later, if someone
> have
> > time for it, it can be updated for the "default" OS, resolution, etc...
> > Alexandre Neto
> > 09:22:
> >> Thanks for the info Richard,
> >> On Fri, Oct 23, 2015 at 10:03 AM, Richard Duivenvoorde <
> richard at duif.net>
> >> wrote:
> >> > On 23-10-15 09:49, Radim Blazek wrote:
> >> >> I want to make some new screenshots so I read guidelines first
> http://docs.qgis.org/2.8/en/docs/documentation_guidelines/README.html#add-new-screenshots
> >> >> where I found:
> >> >> "same environment for all the screen caps (same OS, same decoration,
> >> >> same font size)"
> >> >> It is impossible to satisfy such requirement for all screenshots,
> >> >> until there is somebody making all screenshots on the same system.
> >> >> So what are realistic guidelines? Is there some preferred
> >> >> OS/decoration/font or list of them? Should I just shoot what I have
> on
> >> >> screen now or I shouldn't contribute screenshots at all if I don't
> >> >> have the right OS?
> >> > Hi Radim,
> >> > "just do it" :-)
> >> > I know for the training manual at a certain stage it was updated by
> one
> >> > person with a mac, so he could update all screenshots and we had a
> nice
> >> > and coherent view of screenshot styles.
> >> > But I say: "we better have documentation with Linux screenshots then
> no
> >> > screenshots at all"
> >> could you please also update the guidelines in this sense so that
> >> others are not in doubts.
> >> Radim
> >> > Screenies can always be refined by somebody with the right
> font/os/deco.
> >> > BUT if somebody is aware of certain guidelines (like the preferred
> sizes
> >> > of the dialog images or so)... please step forward and add it to the
> >> > above link.
> >> > And, Radim, thanks for taking the time to do the documentation!!!!
> >> > Regards,
> >> > _______________________________________________
> >> > Qgis-community-team mailing list for organizing community resources
> such
> >> > as documentation, translation etc..
> >> > Qgis-community-team at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> >> Qgis-community-team mailing list for organizing community resources such
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20151023/85d7b1e3/attachment.html>
More information about the Qgis-community-team mailing list
