[Qgis-community-team] Users Manual GRASS integration - what version to use?
Alexandre Neto senhor.neto at gmail.com
Wed Feb 3 09:06:42 PST 2016
I will take advantage of this topic to ask the following:
Is there a GRASS command that we can use to list all available GRASS
modules? I have asked in gis.stackexchange but without sucess.
http://gis.stackexchange.com/questions/179079/how-to-list-the-available-grass-modules-in-command-line/179289#179289
The thing is, at the users manual, we say that there are modules (and
parameters) only available by using the GRASS shell. I think we should
inform the users how to search for those non.gui modules.
In GRASS 7.1 there is now a *g.search.modules* module that do what I was
looking for. For prior versions, at least in linux, you can type `r.` and
press TAB key twice to display all possibilities. But I was trying to find
something more elegant.
Radim Blazek <radim.blazek at gmail.com> escreveu no dia quarta, 3/02/2016 às
10:25:
> On Tue, Feb 2, 2016 at 2:21 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > Hello all,
> > I have been updating the GRASS integration figures. To do that, I
> generally
> > follow the proposed exercises and commands. But GRASS 7.0  introduced
> some
> > changes to modules and the commands (I guess from GRASS 6.4) no longer
> work.
> > Since In QGIS you can now use GRASS 7.0 or GRASS 6.4, in what version
> should
> > be base our documentation. what version should we document?
> > A: Both
> > B: GRASS 6.4
> > C: GRASS 7
> > I would normally go to the C option, but since this actually only appear
> 2
> > or 3 times, It won't hurt much to go for option A, something like this:
> > * Then click **r.relief** (or **r.shaded.relief** if using GRASS 6.4) to
> > open the module.
> This would be the best. Otherwise C and mention that 6.x
> modules/options may slightly differ, pointing to
> https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
> Radim
> > What do you think?
> > Alexandre
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > Qgis-community-team mailing list for organizing community resources such
> as
> > documentation, translation etc..
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160203/66191a74/attachment.html>
More information about the Qgis-community-team mailing list
