[Qgis-community-team] Doc images and github
DelazJ delazj at gmail.com
Wed Jan 27 02:59:07 PST 2016
hi,
@Richard, before proceeding would you mind merging the PR 775 (
https://github.com/qgis/QGIS-Documentation/pull/775)?
It's a long time work on updating and restructuring this chapter. I
expected to push it before your first change but i fail. Then I had to fix
the changes. Would be nice if i can get it reviewed and merged (to avoid
rebasing and other stuffs I'm not yet good at).
Thanks.
2016-01-27 11:28 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> Hi Richard,
> Yes proceed please. Working with vector is a nice chapter to test, as it's
> very abrangent.
> Yves Jacolin <yjacolin at free.fr> escreveu no dia quarta, 27/01/2016 às
> 09:28:
>> Richard,
>> I am not a big contributor. But I am ok with option 2 as well.
>> Y.
>> On Wednesday, January 27, 2016 10:00:39 Richard Duivenvoorde wrote:
>> > Others?
>> > Else I think I'll start to do all whole rst files in working_with_vector
>> > directory and commit in one go. So it can be reversed if we hit
>> problems.
>> > @Alexandre: putting ALL rst file in one dir would indeed help, but I
>> > think we need the structure to be able to eventually build partial
>> > documentation sets.
>> > We could put the substitutions maybe in the index.rst files in the
>> > directory where the images dir also is, but that would also scatter the
>> > substitutions. Then I think having them in de file where you need them
>> > is easiest, also because then you can move around the rst file in the
>> > directory structure without fixing relative paths... (as long as you
>> > copy the images also to the right place off course :-) ).
>> > Anyway: proceed?
>> > Richard
>> > On 26-01-16 14:08, Otto Dassau wrote:
>> > > Hi Richard,
>> > > thanks a lot for this grep/count. In this case I would vote for
>> option 2:
>> > > ..."define figures locally in the rst file where you use them. This
>> has as
>> > > drawback that very often used inline images (like the checkbox) are
>> > > defined
>> > > + image copied very often. BUT the nice thing about it is that IF you
>> > > define them in the rst file, Github is able to resolve those SO they
>> show
>> > > up as inline images there."
>> > > Regards
>> > > Otto
>> > > Am Mon, 25 Jan 2016 21:34:51 +0100
>> > > schrieb Richard Duivenvoorde <richard at duif.net>:
>> > >> On 25-01-16 11:06, Alexandre Neto wrote:
>> > >>> Not an easy choice... I'm not very fond of duplicating substitutions
>> > >>> images as I believe it will lead to pages with different icons
>> because
>> > >>> someone just update one place. Maybe it would be possible to have a
>> > >>> common place with all  images and some kind of script to copy the
>> icons
>> > >>> to a child forder near the rst?
>> > >> FYI, I did a quick grep/count on all substitutions over ALL docs (so
>> not
>> > >> only manual).
>> > >> While I agree with your point... there are not so many images used >
>> 2
>> > >> times...
>> > >> |nix| 45
>> > >> |win| 15
>> > >> |osx| 9
>> > >> |action| 2
>> > >> |analysis| 1
>> > >> |attributes| 4
>> > >> |basic_statistics| 2
>> > >> |browsebutton| 10
>> > >> |buffer| 2
>> > >> |calendarwidget| 0
>> > >> |checkbox| 41
>> > >> |checkbox_checked| 1
>> > >> |checkbox_unchecked| 1
>> > >> |check_geometry| 2
>> > >> |centroids| 2
>> > >> |clip| 2
>> > >> |color| 0
>> > >> |colormap| 0
>> > >> |columnview| 0
>> > >> |combobox| 0
>> > >> |commandlinkbutton| 0
>> > >> |convex_hull| 2
>> > >> |coordinate_capture| 2
>> > >> |copyright_label| 2
>> > >> |CRS| 1
>> > >> |create_gpx| 1
>> > >> |dateedit| 0
>> > >> |datetimeedit| 0
>> > >> |dbmanager| 2
>> > >> |define_projection| 2
>> > >> |delaunay| 2
>> > >> |delimited_text| 2
>> > >> |dem_analysis| 1
>> > >> |diagram| 2
>> > >> |dial| 0
>> > >> |dialogbuttonbox| 0
>> > >> |difference| 2
>> > >> |digitising| 0
>> > >> |dissolve| 2
>> > >> |dockwidget| 0
>> > >> |doublespinbox| 0
>> > >> |dxf2shp_converter| 3
>> > >> |edit| 4
>> > >> |eliminate| 1
>> > >> |event_browser| 1
>> > >> |event_id| 3
>> > >> |evis_connect| 2
>> > >> |evis_file| 2
>> > >> |export_geometry| 2
>> > >> |export_projection| 1
>> > >> |extract_nodes| 2
>> > >> |fontcombobox| 0
>> > >> |frame| 0
>> > >> |ftools| 2
>> > >> |fullCumulativeStretch| 1
>> > >> |FullHistogramStretch| 1
>> > >> |gdal| 1
>> > >> |gdal_about| 0
>> > >> |gdal_assign_projection| 1
>> > >> |gdal_contour| 1
>> > >> |gdal_dem| 1
>> > >> |gdal_edit| 0
>> > >> |gdal_extract_projection| 1
>> > >> |gdal_fillnodata| 1
>> > >> |gdal_grid| 1
>> > >> |gdal_merge| 1
>> > >> |gdal_nearblack| 1
>> > >> |gdal_polygonize| 1
>> > >> |gdal_proximity| 1
>> > >> |gdal_raster-clip| 1
>> > >> |gdal_raster-overview| 1
>> > >> |gdal_raster-paletted| 0
>> > >> |gdal_raster-rgb| 1
>> > >> |gdal_rasterize| 1
>> > >> |gdal_reset| 0
>> > >> |gdal_sieve| 1
>> > >> |gdal_tileindex| 1
>> > >> |gdal_tooltip| 0
>> > >> |gdal_translate| 1
>> > >> |gdal_vrt| 1
>> > >> |gdal_warp| 1
>> > >> |general| 2
>> > >> |gentlelogo| 10
>> > >> |geographic| 3
>> > >> |geometry| 1
>> > >> |geometrychecker| 2
>> > >> |geometrysnapper| 2
>> > >> |geoprocessing| 2
>> > >> |georeferencer| 1
>> > >> |geRasterometry| 0
>> > >> |gps_importer| 2
>> > >> |gpstrack_barchart| 2
>> > >> |gpstrack_polarchart| 2
>> > >> |graphicsview| 0
>> > >> |grass| 2
>> > >> |grass_close_mapset| 2
>> > >> |grass_location| 1
>> > >> |grass_new_mapset| 3
>> > >> |grass_open_mapset| 2
>> > >> |grass_region| 2
>> > >> |grass_set_region| 1
>> > >> |grass_region_edit| 1
>> > >> |grass_tools| 3
>> > >> |groupbox| 0
>> > >> |groupboxcollapsible| 0
>> > >> |heatmap| 4
>> > >> |histogram| 0
>> > >> |hscrollbar| 0
>> > >> |hslider| 0
>> > >> |hsplit| 0
>> > >> |iconAboutConsole| 0
>> > >> |iconClassBrowserConsole| 0
>> > >> |iconClassConsole| 0
>> > >> |iconClassTreeWidgetConsole| 0
>> > >> |iconClearConsole| 0
>> > >> |iconCloseTabEditorConsole| 0
>> > >> |iconCodepadConsole| 0
>> > >> |iconCommentEditorConsole| 0
>> > >> |iconCopyEditorConsole| 0
>> > >> |iconCutEditorConsole| 0
>> > >> |iconFileTabsMenuConsole| 0
>> > >> |iconFunctionTreeWidgetConsole| 0
>> > >> |iconHelpConsole| 0
>> > >> |iconHideToolConsole| 0
>> > >> |iconIfaceConsole| 0
>> > >> |iconMethodTreeWidgetConsole| 0
>> > >> |iconNewTabEditorConsole| 0
>> > >> |iconOpenConsole| 0
>> > >> |iconPasteEditorConsole| 0
>> > >> |iconQtCoreConsole| 0
>> > >> |iconQtGuiConsole| 0
>> > >> |iconRestoreTabsConsole| 0
>> > >> |iconRunConsole| 0
>> > >> |iconRunScriptConsole| 0
>> > >> |iconSaveAsConsole| 0
>> > >> |iconSaveConsole| 0
>> > >> |iconScriptConsole| 0
>> > >> |iconSettingsConsole| 0
>> > >> |icon_newgpx| 1
>> > >> |icon_dbmanager| 3
>> > >> |icon_zonal_statistics| 1
>> > >> |import_gpx| 1
>> > >> |inputtext| 2
>> > >> |interpolation| 2
>> > >> |intersect| 2
>> > >> |intersections| 2
>> > >> |join| 2
>> > >> |join_location| 2
>> > >> |labels| 1
>> > >> |layer_extent| 2
>> > >> |locale| 1
>> > >> |locked| 2
>> > >> |mAction| 3
>> > >> |mActionAdd| 1
>> > >> |mActionAddAllToOverview| 2
>> > >> |mActionAddArrow| 3
>> > >> |mActionAddBasicShape| 3
>> > >> |mActionAddDelimitedTextLayer| 0
>> > >> |mActionAddGCPPoint| 1
>> > >> |mActionAddHtml| 2
>> > >> |mActionAddImage| 3
>> > >> |mActionAddLayer| 1
>> > >> |mActionAddLegend| 5
>> > >> |mActionAddMap| 6
>> > >> |mActionAddMssqlLayer| 2
>> > >> |mActionAddNonDbLayer| 1
>> > >> |mActionAddOgrLayer| 4
>> > >> |mActionAddOracleLayer| 1
>> > >> |mActionAddPart| 4
>> > >> |mActionAddPostgisLayer| 2
>> > >> |mActionAddRasterLayer| 7
>> > >> |mActionAddRing| 4
>> > >> |mActionAddSpatiaLiteLayer| 3
>> > >> |mActionAddWmsLayer| 3
>> > >> |mActionAlignBottom| 2
>> > >> |mActionAlignHCenter| 2
>> > >> |mActionAlignLeft| 4
>> > >> |mActionAlignRight| 2
>> > >> |mActionAlignTop| 2
>> > >> |mActionAlignVCenter| 2
>> > >> |mActionAllEdits| 2
>> > >> |mActionAnnotation| 2
>> > >> |mActionArrowDown| 1
>> > >> |mActionArrowLeft| 0
>> > >> |mActionArrowRight| 1
>> > >> |mActionArrowUp| 0
>> > >> |mActionAtlasFirst| 2
>> > >> |mActionAtlasLast| 2
>> > >> |mActionAtlasNext| 2
>> > >> |mActionAtlasPrev| 2
>> > >> |mActionAtlasSettings| 1
>> > >> |mActionCancelEdits| 1
>> > >> |mActionCalculateField| 6
>> > >> |mActionCaptureBoundary| 1
>> > >> |mActionCaptureCentroid| 1
>> > >> |mActionCaptureLine| 4
>> > >> |mActionCapturePoint| 4
>> > >> |mActionCapturePolygon| 5
>> > >> |mActionChangeLabelProperties| 2
>> > >> |mActionCheckQgisVersion| 2
>> > >> |mActionCollapseTree| 2
>> > >> |mActionComposerManager| 4
>> > >> |mActionContextHelp| 1
>> > >> |mActionCopySelected| 3
>> > >> |mActionCustomProjection| 3
>> > >> |mActionDeleteAttribute| 3
>> > >> |mActionDeleteGCPPoint| 1
>> > >> |mActionDeletePart| 4
>> > >> |mActionDeleteRing| 4
>> > >> |mActionDeleteSelected| 4
>> > >> |mActionDeselectAll| 2
>> > >> |mActionDraw| 5
>> > >> |mActionDupComposer| 2
>> > >> |mActionDuplicateLayer| 1
>> > >> |mActionEditCopy| 5
>> > >> |mActionEditCut| 4
>> > >> |mActionEditPaste| 4
>> > >> |mActionExpandNewTree| 2
>> > >> |mActionExpandTree| 2
>> > >> |mActionExportMapServer| 1
>> > >> |mActionFileExit| 2
>> > >> |mActionFileNew| 3
>> > >> |mActionFileOpen| 6
>> > >> |mActionFilePrint| 5
>> > >> |mActionFileSave| 6
>> > >> |mActionFileSaveAs| 9
>> > >> |mActionFillRing| 2
>> > >> |mActionFilter| 1
>> > >> |mActionFolder| 2
>> > >> |mActionFormAnnotation| 2
>> > >> |mActionFullHistogramStretch| 1
>> > >> |mActionGDALScript| 2
>> > >> |mActionGroupItems| 2
>> > >> |mActionHelpAbout| 2
>> > >> |mActionHelpContents| 2
>> > >> |mActionHelpSponsors| 2
>> > >> |mActionHideAllLayers| 2
>> > >> |mActionmIconExpressionEditorOpen| 1
>> > >> |mActionIdentify| 6
>> > >> |mActionInOverview| 2
>> > >> |mActionInvertSelection| 2
>> > >> |mActionLabel| 4
>> > >> |mActionLabeling| 4
>> > >> |mActionLink| 1
>> > >> |mActionLinkGeorefToQGis| 2
>> > >> |mActionLinkQGisToGeoref| 2
>> > >> |mActionLoadGCPpoints| 1
>> > >> |mActionLocalHistogramStretch| 1
>> > >> |mActionLowerItems| 2
>> > >> |mActionMapTips| 3
>> > >> |mActionMeasure| 3
>> > >> |mActionMeasureAngle| 2
>> > >> |mActionMeasureArea| 2
>> > >> |mActionMergeFeatAttributes| 3
>> > >> |mActionMergeFeatures| 3
>> > >> |mActionMoveFeature| 4
>> > >> |mActionMoveGCPPoint| 1
>> > >> |mActionMoveItemContent| 4
>> > >> |mActionMoveItemsToBottom| 2
>> > >> |mActionMoveItemsToTop| 2
>> > >> |mActionMoveLabel| 2
>> > >> |mActionNewAttribute| 3
>> > >> |mActionNewBookmark| 2
>> > >> |mActionNewComposer| 6
>> > >> |mActionNewSpatiaLiteLayer| 2
>> > >> |mActionNewVectorLayer| 3
>> > >> |mActionNodeTool| 4
>> > >> |mActionOffsetCurve| 4
>> > >> |mActionOpenRaster| 0
>> > >> |mActionOpenTable| 7
>> > >> |mActionOptions| 9
>> > >> |mActionPan| 6
>> > >> |mActionPinLabels| 1
>> > >> |mActionProjectProperties| 3
>> > >> |mActionPropertyItem| 2
>> > >> |mActionQgisHomePage| 2
>> > >> |mActionRaiseItems| 3
>> > >> |mActionRedo| 5
>> > >> |mActionRemove| 1
>> > >> |mActionRemoveAllFromOverview| 1
>> > >> |mActionRemoveLayer| 3
>> > >> |mActionReshape| 4
>> > >> |mActionRollbackEdits| 1
>> > >> |mActionRotateFeature| 1
>> > >> |mActionRotateLabel| 1
>> > >> |mActionRotatePointSymbols| 3
>> > >> |mActionSaveAsPDF| 4
>> > >> |mActionSaveAsSVG| 5
>> > >> |mActionSaveEdits| 3
>> > >> |mActionSaveGCPpointsAs| 1
>> > >> |mActionSaveMapAsImage| 6
>> > >> |mActionScaleBar| 4
>> > >> |mActionSelect| 10
>> > >> |mActionSelectFreehand| 2
>> > >> |mActionSelectPan| 1
>> > >> |mActionSelectPolygon| 2
>> > >> |mActionSelectRadius| 2
>> > >> |mActionSelectRectangle| 2
>> > >> |mActionSelectedToTop| 2
>> > >> |mActionShowAllLayers| 3
>> > >> |mActionShowBookmarks| 2
>> > >> |mActionShowHideLabels| 1
>> > >> |mActionShowPinnedLabels| 1
>> > >> |mActionShowPluginManager| 6
>> > >> |mActionShowPresets| 3
>> > >> |mActionSignMinus| 3
>> > >> |mActionSignPlus| 6
>> > >> |mActionSimplify| 4
>> > >> |mActionSplitFeatures| 5
>> > >> |mActionSplitParts| 3
>> > >> |mActionStartGeoref| 2
>> > >> |mActionTextAnnotation| 2
>> > >> |mActionToggleEditing| 6
>> > >> |mActionTouch| 1
>> > >> |mActionTransformSettings| 2
>> > >> |mActionUndo| 5
>> > >> |mActionUnGroupItems| 1
>> > >> |mActionUnlink| 1
>> > >> |mActionUnselectAttributes| 1
>> > >> |mActionWhatsThis| 2
>> > >> |mActionZoomActual| 3
>> > >> |mActionZoomFullExtent| 5
>> > >> |mActionZoomIn| 8
>> > >> |mActionZoomLast| 3
>> > >> |mActionZoomNext| 3
>> > >> |mActionZoomOut| 8
>> > >> |mActionZoomToLayer| 4
>> > >> |mActionZoomToSelected| 4
>> > >> |management| 1
>> > >> |mapserver_export| 1
>> > >> |matrix| 2
>> > >> |mean| 2
>> > >> |merge_shapes| 2
>> > >> |metadata| 2
>> > >> |metasearch| 2
>> > >> |mGeorefRun| 1
>> > >> |mIconAtlas| 3
>> > >> |mIconColorBox| 2
>> > >> |mIconColorPicker| 2
>> > >> |mIconColorSwatches| 2
>> > >> |mIconColorWheel| 2
>> > >> |mIconDataDefine| 6
>> > >> |mIconExpression| 1
>> > >> |mIconExpressionSelect| 4
>> > >> |mIconImport| 1
>> > >> |mIconLock| 2
>> > >> |mIconNew| 2
>> > >> |mIconProjectionDisabled| 2
>> > >> |mIconProjectionEnabled| 3
>> > >> |mIconRasterGroup| 1
>> > >> |mIconRasterLink| 1
>> > >> |mIconStopRendering| 1
>> > >> |mIconZip| 1
>> > >> |multi_to_single| 2
>> > >> |neighbor| 2
>> > >> |north_arrow| 2
>> > >> |offline_editing_copy| 3
>> > >> |offline_editing_sync| 2
>> > >> |oracle_raster| 3
>> > >> |osm_addRelation| 1
>> > >> |osm_createLine| 1
>> > >> |osm_createPoint| 1
>> > >> |osm_createPolygon| 1
>> > >> |osm_createRelation| 1
>> > >> |osm_download| 1
>> > >> |osm_editRelation| 1
>> > >> |osm_featureManager| 1
>> > >> |osm_generateTags| 1
>> > >> |osm_identify| 1
>> > >> |osm_import| 1
>> > >> |osm_load| 1
>> > >> |osm_move| 1
>> > >> |osm_questionMark| 1
>> > >> |osm_removeFeat| 1
>> > >> |osm_removeTag| 0
>> > >> |osm_save| 1
>> > >> |osm_upload| 0
>> > >> |PanToSelected| 3
>> > >> |pencil| 2
>> > >> |plugin| 3
>> > >> |plugin_installed| 1
>> > >> |plugin_installer| 2
>> > >> |plugin_upgrade| 1
>> > >> |proc_commander| 1
>> > >> |proc_history| 1
>> > >> |proc_model| 1
>> > >> |proc_option| 1
>> > >> |proc_result| 1
>> > >> |proc_toolbox| 1
>> > >> |qgissplash| 0
>> > >> |radiobuttonon| 15
>> > >> |radiobuttonoff| 10
>> > >> |random_points| 2
>> > >> |random_selection| 2
>> > >> |raster-info| 3
>> > >> |raster-interpolate| 2
>> > >> |raster-stats| 2
>> > >> |raster_terrain| 2
>> > >> |regular_points| 2
>> > >> |RemoveAllOVerview| 2
>> > >> |roadgraph| 1
>> > >> |sampling| 1
>> > >> |scale_bar| 2
>> > >> |selectcolor| 3
>> > >> |selectcreatelayer| 2
>> > >> |selectnumber| 9
>> > >> |selectstring| 17
>> > >> |selectesubsetlayer| 2
>> > >> |select_location| 2
>> > >> |ShowRasterCalculator| 1
>> > >> |single_to_multi| 2
>> > >> |slider| 6
>> > >> |spatialquery| 3
>> > >> |spiticon| 2
>> > >> |split_layer| 2
>> > >> |sub_selection| 2
>> > >> |sum_lines| 2
>> > >> |sum_points| 2
>> > >> |sym_difference| 2
>> > >> |symbology| 1
>> > >> |simplify| 2
>> > >> |tab| 1
>> > >> |to_lines| 2
>> > >> |topologychecker| 2
>> > >> |tracking| 2
>> > >> |transformed| 1
>> > >> |union| 2
>> > >> |unique| 2
>> > >> |unlocked| 2
>> > >> |user| 1
>> > >> |vector_grid| 2
>> > >> |wcs| 1
>> > >> |wfs| 4
>> > >> _______________________________________________
>> > >> Qgis-community-team mailing list for organizing community resources
>> such
>> > >> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> > >> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> such as
>> > documentation, translation etc.. Qgis-community-team at lists.osgeo.org
>> Qgis-community-team mailing list for organizing community resources such
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetaswordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160127/1cc67544/attachment-0001.html>
More information about the Qgis-community-team mailing list
