[Qgis-community-team] 3D view of LIDAR data city of boulder
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Mon Feb 10 01:04:58 PST 2020
Hi Alexandre,
I am not sure about the licensing of the data.
For mesh layer, there are already some datasets for test suite, which
should be good for documentation too:
https://github.com/lutraconsulting/MDAL/tree/master/tests/data
Kind regards
Saber
On Sun, 9 Feb 2020 at 12:48, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Can we consider creating/clipping a open 3D sample data that we could add
> to QGIS Sample data?
> This would be useful for when someone else wants to update the
> documentation.
> Same goes for mesh data.
> Thanks,
> Alexandre Neto
> A sábado, 8/02/2020, 12:38, Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk> escreveu:
>> Hi Larissa,
>> Apologies. Boulder data indeed contain walls and roofs.
>> To view the data in 3D, you need to go to each layer and open
>> Properties > 3D view and change the style to Single symbol.
>> Also, the dataset is very large. It would be easier if you crop the data
>> to a smaller area.
>> Regards
>> Saber
>> On Sat, 8 Feb 2020 at 12:00, Saber Razmjooei <
>> saber.razmjooei at lutraconsulting.co.uk> wrote:
>>> Hi Larissa,
>>> Many thanks for looking into documenting this.
>>> I had a quick look at the data. It is only the footprint. So, you can
>>> only extrude the data (based on height).
>>> There is a good data source of 3D buildings here:
>>> https://github.com/wonder-sk/3d-spatial-data
>>> And for building in New York, we wrote a blog post here. The data have
>>> z-valuse and should automatically get picked up by the 3D map view.
>>> https://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
>>> Feel free to use any of the content from our website in the
>>> documentation.
>>> Kind regards
>>> Saber
>>> On Fri, 7 Feb 2020 at 13:59, Larissa Junek <l.junek at gmx.net> wrote:
>>>> Hello folks,
>>>> for documentation purposes I'd like to visualize the 3d data of the city
>>>> of boulder in qgis 3.10 .
>>>> https://bouldercolorado.gov/open-data/city-of-boulder-3d-buildings/
>>>> Unfortunately qgis crashes when loading the shapefile into the 3d view.
>>>> Also, where do I have access to the z-coordinate so that there will be a
>>>> 3d view. At the moment there is only visible a plane with the vectors
>>>> but no "z-value"  in the 3d view application. Extrusion doesn't help
>>>> solute the problem.
>>>> There is a hint that these data have something to do with GeoJSon, so
>>>> maybe I have to find another 3d data suitable for using in the 3D view
>>>> application.
>>>> Can somebody help?
>>>> Cheers, Larissa
>>>> _______________________________________________
>>>> Qgis-community-team mailing list for organizing community resources
>>>> such as documentation, translation etc..
>>>> Qgis-community-team at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>> Saber Razmjooei
>>> +44 (0)7568 129733
>> Saber Razmjooei
>> +44 (0)7568 129733
>> Qgis-community-team mailing list for organizing community resources such
Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200210/45611a13/attachment.html>
More information about the Qgis-community-team mailing list
