[Qgis-community-team] pdf testing build failing
Richard Duivenvoorde
rdmailings at duif.net
Fri Mar 4 00:09:32 PST 2022
Hi, Any Latex/PDF guru's here?
The pdf build of current testing version of the docs is failing.
Normally we do a Latex build and after that a pdf generation.
3.16 is still fine (build yesterday I see in pdf of 3.16)
But building testing here locally:
Latex build is fine, then pdf generation generates output below.
I'm thinking about a poissonous GIF image? Anybody aware of maybe animated gifs or so?
See below for the build error
Regards,
This is XeTeX, Version 3.141592653-2.6-0.999993 (TeX Live 2022/dev/Debian) (preloaded format=xelatex)
\write18 enabled.
entering extended mode
Error: /undefined in GIF89ax��
Operand stack:
Execution stack:
%interp_exit .runexec2 --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push --nostringval-- --nostringval-- --nostringval-- false 1 %stopped_push 1990 1 3 %oparray_pop 1989 1 3 %oparray_pop 1977 1 3 %oparray_pop 1833 1 3 %oparray_pop --nostringval-- %errorexec_pop .runexec2 --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push --nostringval--
Dictionary stack:
--dict:770/1123(ro)(G)-- --dict:0/20(G)-- --dict:75/200(L)--
Current allocation mode is local
Current file position is 12
GPL Ghostscript 9.55.0: Unrecoverable error, exit code 1
xdvipdfmx:fatal: pdf_link_obj(): passed invalid object.
No output PDF file written.
\write18 enabled.
Operand stack:
Execution stack:
Dictionary stack:
More information about the Qgis-community-team
