[Qgis-developer] Re: [Qgis-user] Trial debian / ubuntu packages for
QGIS SVN / 0.8 preview
Tim Sutton
tim at linfiniti.com
Mon Apr 17 05:28:35 EDT 2006
Hi Trevor
Thanks for the feedback. My apologies I should have mentioned I build
using ubuntu dapper. I will probably need to build the package again
on breezy, though I am not sure if qt4.1 is available via apt in
breezy. Could you check on that for me? If it is I will try to set up
a chroot running breezy and build qgis debs in the chroot environment.
Were any debian users able to use the packages sucsessfully?
Regards
Tim
On 4/17/06, Trevor Wiens <twiens at interbaun.com> wrote:
> On Mon, 17 Apr 2006 03:20:27 +0100
> "Tim Sutton" <tim at linfiniti.com> wrote:
> > Hi Folks
> > I've spent some time updating things to get .deb packaging working
> > again for Debian & Ubuntu. I've made a test package and would be
> > grateful for any feedback from the general community - do the packages
> > work, does QGIS run ok from the packages etc.
> > http://qgis.org/uploadfiles/qgis_0.7.9+svn17042006_i386.deb
> > http://qgis.org/uploadfiles/qgis-plugin-grass_0.7.9+svn17042006_i386.deb
> Tim,
> I'm not sure what version of Ubuntu you are intending this for. I'm
> running breezy and go the following:
> dpkg -i qgis_0.7.9+svn17042006_i386.deb qgis-plugin-grass_0.7.9+svn17042006_i386.deb
> Selecting previously deselected package qgis.
> (Reading database ... 135807 files and directories currently installed.)
> Unpacking qgis (from qgis_0.7.9+svn17042006_i386.deb) ...
> Selecting previously deselected package qgis-plugin-grass.
> Unpacking qgis-plugin-grass (from qgis-plugin-grass_0.7.9+svn17042006_i386.deb) ...
> dpkg: dependency problems prevent configuration of qgis:
> qgis depends on libgcc1 (>= 1:4.0.2); however:
> Version of libgcc1 on system is 1:4.0.1-4ubuntu9.
> qgis depends on libgdal1c2a (>= 1.2.6); however:
> Package libgdal1c2a is not installed.
> qgis depends on libgeos2c2a; however:
> Package libgeos2c2a is not installed.
> qgis depends on libqt4-core (>= 4.1.0); however:
> Version of libqt4-core on system is 4.0.0-3ubuntu1.
> qgis depends on libqt4-qt3support (>= 4.1.0); however:
> Version of libqt4-qt3support on system is 4.0.0-3ubuntu1.
> qgis depends on libsqlite3-0 (>= 3.2.8); however:
> Version of libsqlite3-0 on system is 3.2.1-1.
> qgis depends on libstdc++6 (>= 4.0.2-4); however:
> Version of libstdc++6 on system is 4.0.1-4ubuntu9.
> qgis depends on qt4-designer (>= 4.1.0); however:
> Package qt4-designer is not installed.
> dpkg: error processing qgis (--install):
> dependency problems - leaving unconfigured
> dpkg: dependency problems prevent configuration of qgis-plugin-grass:
> qgis-plugin-grass depends on qgis (= 0.7.9+svn17042006); however:
> Package qgis is not configured yet.
> qgis-plugin-grass depends on libgdal1-grass (>= 1.2.6-0); however:
> Package libgdal1-grass is not installed.
> dpkg: error processing qgis-plugin-grass (--install):
> Errors were encountered while processing:
> qgis
> qgis-plugin-grass
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
