[Qgis-developer] SVN 5298 doesn't build
Maciek Sieczka werchowyna at epf.pl
Tue Apr 18 04:51:44 EDT 2006
Hi
Current SVN doesn't build on my Ubuntu Breezy. On make I get:
$ make
make: *** No targets specified and no makefile found.  Stop.
What could that be?
The configure was:
$ ./autogen.sh --with-qtdir=/usr/local/Trolltech/Qt-4.1.2/
--prefix=/usr/local --with-grass=/usr/local/grass-6.1.cvs --with-python
./autogen.sh: line 30: [: 1: unary operator expected
./autogen.sh: line 33: [: 1: unary operator expected
Configuring build environment for QGIS
configure.in:281: warning: AC_PROG_LEX invoked multiple times
autoconf/programs.m4:438: AC_DECL_YYTEXT is expanded from...
aclocal.m4:7843: AM_PROG_LEX is expanded from...
configure.in:281: the top level
configure.in: 20: `automake requires `AM_CONFIG_HEADER', not
`AC_CONFIG_HEADER' Makefile.am:33: HAVE_QT4 does not appear in
AM_CONDITIONAL i18n/Makefile.am:19: invalid variable `nodist_i18n_DATA'
src/Makefile.am:11: HAVE_QTMAC does not appear in AM_CONDITIONAL
src/composer/Makefile.am:16: endif without if
src/core/Makefile.am:16: HAVE_QTMAC does not appear in AM_CONDITIONAL
src/core/Makefile.am:25: endif without if
src/core/Makefile.am:155: variable `postgresMOC' not defined
src/core/Makefile.am:169: variable `qgisHEADERS' not defined
src/core/Makefile.am:153: invalid unused variable name:
`nodist_libqgis_core_la_SOURCES' src/helpviewer/Makefile.am:55:
src/helpviewer/Makefile.am:43: variable `LDADD' not defined
src/gui/Makefile.am:21: endif without if src/gui/Makefile.am:31:
HAVE_QTMAC does not appear in AM_CONDITIONAL src/gui/Makefile.am:52:
HAVE_QTMAC does not appear in AM_CONDITIONAL src/gui/Makefile.am:271:
HAVE_POSTGRESQL does not appear in AM_CONDITIONAL
src/gui/Makefile.am:196: libqgis_gui_la_SOURCES defined both
conditionally and unconditionally src/gui/Makefile.am:316:
src/gui/Makefile.am:314: EXTRA_DIST defined both conditionally and
unconditionally src/gui/Makefile.am:307: pkginclude_HEADERS defined
both conditionally and unconditionally src/gui/Makefile.am:51: variable
`LDADD' not defined src/gui/Makefile.am: qgis_OBJECTS should not be
defined src/gui/Makefile.am:51: variable `LDADD' not defined
src/gui/Makefile.am:294: variable `qgis_YACC' not defined
src/gui/Makefile.am:307: variable `qgisHEADERS' not defined
src/gui/Makefile.am:307: variable `libqgisHEADERS' not defined
automake: src/gui/Makefile.am: warning: automake does not support
EXTRA_DIST being defined conditionally src/gui/Makefile.am:314:
warning: automake does not support conditional definition of
postgresSOURCES in EXTRA_DIST src/gui/Makefile.am:314: warning:
automake does not support conditional definition of postgresLIBSOURCES
in EXTRA_DIST src/gui/Makefile.am:292: invalid unused variable name:
`nodist_libqgis_gui_la_SOURCES' src/legend/Makefile.am:15: endif
without if src/plugins/Makefile.am:3: HAVE_SPIT does not appear in
AM_CONDITIONAL src/plugins/Makefile.am:7: HAVE_POSTGRESQL does not
appear in AM_CONDITIONAL src/plugins/Makefile.am:11: HAVE_GRASS does
not appear in AM_CONDITIONAL src/plugins/Makefile.am:16: variable
`COMMUNITY' not defined src/plugins/Makefile.am:16: variable
`COMMUNITY' not defined src/plugins/geoprocessing/Makefile.am:44:
invalid unused variable name: `nodist_pggeoprocessingplugin_la_SOURCES'
src/plugins/georeferencer/Makefile.am:14: HAVE_GSL does not appear in
AM_CONDITIONAL automake: src/plugins/georeferencer/Makefile.am:
warning: automake does not support georefplugin_la_LDFLAGS being
defined conditionally automake: src/plugins/georeferencer/Makefile.am:
warning: automake does not support EXTRA_DIST being defined
conditionally src/plugins/georeferencer/Makefile.am:84: warning:
automake does not support conditional definition of plugin_UIC in
EXTRA_DIST src/plugins/georeferencer/Makefile.am:75: invalid unused
variable name: `nodist_georefplugin_la_SOURCES'
src/plugins/gps_importer/Makefile.am:13: HAVE_EXPAT does not appear in
AM_CONDITIONAL automake: src/plugins/gps_importer/Makefile.am: warning:
automake does not support gpsimporterplugin_la_LDFLAGS being defined
conditionally automake: src/plugins/gps_importer/Makefile.am: warning:
automake does not support EXTRA_DIST being defined conditionally
src/plugins/gps_importer/Makefile.am:74: warning: automake does not
support conditional definition of plugin_UIC in EXTRA_DIST
src/plugins/grass/Makefile.am:21: endif without if automake:
src/plugins/grass/Makefile.am: not supported: source file
`../../providers/grass/qgsgrass.h' is in subdirectory automake:
`../../providers/grass/qgsgrassprovider.h' is in subdirectory
src/plugins/grass/Makefile.am:102: invalid unused variable name:
`nodist_grassplugin_la_SOURCES' src/plugins/grid_maker/Makefile.am:15:
endif without if src/plugins/north_arrow/Makefile.am:16: endif without
if src/plugins/spit/Makefile.am:64: variable `SPIT_UIC' not defined
automake: src/plugins/spit/Makefile.am: not supported: source file
`../../gui/qgsmessageviewer.cpp' is in subdirectory automake:
`../../gui/qgspgutil.cpp' is in subdirectory
src/plugins/spit/Makefile.am:66: invalid unused variable name:
`nodist_spitplugin_la_SOURCES' src/providers/Makefile.am:1:
src/providers/Makefile.am:5: HAVE_GRASS does not appear in
AM_CONDITIONAL src/providers/delimitedtext/Makefile.am:11: variable
`GDAL_LIB' not defined src/providers/gpx/Makefile.am:3: HAVE_EXPAT does
not appear in AM_CONDITIONAL automake: src/providers/gpx/Makefile.am:
warning: automake does not support gpxprovider_la_LDFLAGS being defined
conditionally automake: src/providers/gpx/Makefile.am: warning:
src/providers/grass/Makefile.am:38: HAVE_POSTGRESQL does not appear in
AM_CONDITIONAL src/providers/grass/Makefile.am:37:
libqgisgrass_la_CXXFLAGS defined both conditionally and unconditionally
automake: src/providers/wms/Makefile.am: not supported: source file
`../../core/qgsdataprovider.moc.cpp' is in subdirectory automake:
`../../core/qgsrasterdataprovider.moc.cpp' is in subdirectory
src/raster/Makefile.am:1: HAVE_QTMAC does not appear in AM_CONDITIONAL
automake: src/ui/Makefile.am: not supported: source file
`../widgets/projectionselector/ui_qgsprojectionselectorbase.h' is in
subdirectory src/widgets/projectionselector/Makefile.am:18: endif
without if src/widgets/projectionselector/Makefile.am:46: variable
`LDADD' not defined tools/Makefile.am:12: USE_PYTHON does not appear in
AM_CONDITIONAL tests/src/core/Makefile.am: testqgsapplication_OBJECTS
should not be defined tests/src/core/Makefile.am:79: variable
`testqgsbookmarkitem_MOC' not defined tests/src/core/Makefile.am:79:
variable `testqgsdistancearea_MOC' not defined
tests/src/core/Makefile.am:79: variable `testqgslabelattributes_MOC'
not definedtests/src/gui/Makefile.am:553: invalid unused variable name:
`testqgsvectorsymbologywidget_SOURCES' tests/src/gui/Makefile.am:554:
invalid unused variable name: `testqgsvectorsymbologywidget_LDADD'
tests/src/gui/Makefile.am:309: invalid unused variable name:
`testqgslabel_LDADD' tests/src/gui/Makefile.am:263: invalid unused
variable name: `testqgsdbsourceselect_SOURCES'
tests/src/gui/Makefile.am:264: invalid unused variable name:
`testqgsdbsourceselect_LDADD' tests/src/gui/Makefile.am:308: invalid
unused variable name: `testqgslabel_SOURCES'
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
