[Qgis-developer] please, help me... Radim
Tim Sutton tim at linfiniti.com
Wed Aug 23 14:03:49 EDT 2006
Hi
There is no need to do so much work - we have made a re-useable cross
compilation environment in a chroot jail. It can be downloaded from
here:
http://gisalaska.com/torrents/mingw_chroot.tar.bz2
Regards
Tim
On 8/23/06, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> Dear Radim Blazek,
> In first thanks a lot for your great article "BuildingWindowsBinaryOnLinux".
> I am new in QGIS development.
> I want to write simple plug-in for my own purpose, therefore I need to
> compile QGIS for Windows platform. In first time I was using Mateusz
> Loskot's HOWTO (Building Quantum GIS with Visual C++ 2005). However I can
> not compile latest QGIS source for myself. I have been getting lot of
> compiler errors; I was so many times to trying compiling QGIS using Visual
> C++ 2005 on the windows XP. Of course I my compilation progress is improved,
> although still so many strange compiler errors alert to me.
> After that I was decide to using yours HOWTO.
> Every thing is OK until GRASS compilation. In GRASS compilation process had
> some compilation error. Please look at attached "error.log" file. I have
> using GRASS 6.3 source from CVS repository which is noted in your HOWTO.
> Then next step is "GDAL GRASS support" processing. This step is so buggy for
> my compiling time. After I recompiling according your HOWTO then I had error
> occurred please see it from attached file "gdal-winmake-error".
> In finally I have compiling QGIS without-postgresql option (according
> HOWTO); however I found many errors in SPIT plug-in compiling also
> postgresql related things. Why it was occurs for me, I was specifying in
> QGIS for without-postgresql.
> In the end please help me, what I will do for compiling QGIS within
> PostgreSQL support, should I compile PostgreSQL from source distro? If yes
> then which configure script and make util I have to use? Simple Linux
> configure script or winconfigure within winmake and winmake install?
> Thanks for reading my so long and so boring email.
> I hope you will help to me; I am looking your reply.
> Best regards,
>         Byambaa Mendbayar
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
